#1 |
If my bore is 3.328 with a 4" stroke, is my motor 278.xx ci or am I missing something?
Thank, Joe |
#2 |
278.36
#3 |
#4 |
It is the volume of a cylinder - (pi x r sq) X stroke OR (pi x d/2 sq) x stroke.
3.328/2 = 1.664 sq = 2.769 x pi = 8.699 x 4.00 = 34.795 which is volume of one cylinder so x 8 = 278.36 |
#5 |
#6 |
This is the way I've been figuring it since I first started reading "Hot Rod Magazine" around 1961. Bore X Bore X Stroke X .7854 X Number of Cylinders. 3.328 X 3.328 X 4 X .7854 X 8 = 278.36 Cu. In. |
#7 |
#8 |
Thanks everyone!
#9 |
3.328?????? 3.312= 3 5/16. 3.328 = 3 5/16 +.016. Strange bore?
Gramps |
#10 |
Cylinder wear?
#11 |
3.328/2 = 1.664 sq = 2.769 x pi = 8.699 x 4.00 = 34.795 is volume of one cylinder so x 8 = 278.36
DJ E Feezy |
#12 |
I've seem pistons for 3 5/16" (3.3125") and 3 3/8" (3.375") but 3.328" not so much.
#13 | |
I do remember him telling me he wanted to keep the bore as tight as possible and not remove to much material because it's a blower motor. There's a note on my paperwork that says "8BA-Std Bore-Needs O/B (.040") I hope this makes sense. Thanks Joe |
#14 | |
3-5/16" (3.3125") is a standard overbore. IF your bores actually measure 3.328", that means that you're going to have roughly 0.016" PISTON CLEARANCE in each bore, which some of us are finding a little hard to understand.....IF the pistons ARE actually 3-5/16" pieces. Are you sure that your bore isn't 3.228" rather than your stated 3.328? That would make sense as a +.040" oversize. DD . |
#15 |
Quote: "Are you sure that your bore isn't 3.228" rather than your stated 3.328? That would make sense as a +.040" oversize. DD"
...in which case your displacement would be 261.88 cu. in. ![]() Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '30 Model A Speedster '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302
#16 |
Sounds like it is just .040 over to me . . .
#17 |
Pistons can be cut down and new ones can be custom made but Egge does make some larger oversizes than 3.3125" in the Mercury type 4-inch stroke. No telling what Gary came up with.
The Egge 3-ring pistons go up from .125" oversize in .010" increments. Last edited by rotorwrench; 09-03-2021 at 11:38 AM. |
#18 | |
Thank you! Joe |
#19 |
I miss Gary, bought a Stricker assy from him a few years back, still running fine. Ses if your gona run allot of boost it's best to keep a thicker wall. 10 lbs of boos will do more for power then a large Overbore. Have a 294 blower motor putting out 235 hP on 4 lba od boost at 4500. Makes a nice street machine, Wonder what it makes a 5k, but he shut the beast down to sabe it. #$$$$$$$
#20 | |
Air/fuel is 12.3 at WOT at that rpm Thanks Joe |
