#1 |
Hi All.. Just wondering if a relieved block has anything to gain over the standard type block. Do you think it might be prone to burning exhaust valves because the outside edge is more exposed during combustion?
Regards Kevin. I've just acquired a relieved motor. was told it was from a Brengun carrier. It's not the type of thing I would do to an engine myself. This is the second one to have passed through my hands. The first one was recovered from a boat in the 1980's and the sump was full of sand. I noticed that the heads were different in the area over the piston tops. They had much more meat covering 'more' than half of the piston. I assumed this was to compensate for the loss of material from the block so as not reduce compression. I think I still have these heads in my stash. Could I bolt them onto a standard unrelieved block to increase compression? Last edited by Fatheads4ever; 08-21-2021 at 04:10 PM. Reason: Adding additional info |
#2 |
#3 |
Heck, that looks like my work! God only knows I've relieved a few flatheads . . . of all shapes and sizes. LOL
Most of us flathead horsepower chasers believe that relieving a block helps at higher RPMS, with a well ported engine, with a cam that needs it, bigger valves, etc.. If you're creating a typical street flathead and are not really going all out for higher RPMs (over 4500 or so), and don't do the REST of the necessary valvetrain work, then you'll probably gain nothing from a relief. Actually you'll probably hurt lower RPM performance as you're reducing the compression ratio. This is a real consideration for most street engines . . . who don't have the ports, the valve sizes, the cam, the RPMs or the lower-ends to use a relief. So, there yah have it . . . I relieve all my engines, but I don't build the type that most build. Also, as I wrote in my article - there are as many opinions as bung-holes on the subject . . . pick the ones you like, listen to whatever 'guru' floats your boat! LOL. Boy, I'm RELIEVED I got this off my ole' chest . . . B&S |
#4 |
I relieved one of mine. Run a 3/4 Iskederian cam . 11:1 Offenhauser heads , stalite valves and tri power carb set up. Been on the road for over 30 years . Still running great.
Vic |
#5 |
Could you please share how you are able to get 11:1 compression on a relieved engine? Do you have a large displacement engine? Can you tell us how may ci?
#6 | |
Everything else is just 'puffery'. |
#7 |
#8 |
I don't believe in relieving the block anymore. I did back in my early days , but after due consideration in airflow decided that relieving a block was a waste of time and just lowered compression. So for the last 50 years I skipped this mod. Besides, it makes it hard to install rings in the bore.
Gramps |
#9 | |
#10 |
Wonder if unrelieving is possible? Jack E/NJ
#11 | |
It runs on regular pump gas and reliable to drive. Vic |
#12 | |
Per the chart, my 284" factory relieved engine with .425 Offy heads has a compression ratio of 8.5, which is pretty close to optimum for a street engine. Runs strong with no pinging on regular gas and timing mark advanced 3 degrees. Last edited by drolston; 08-21-2021 at 03:28 PM. |
#13 |
A relieved block can take advantage of the crow foot chamber shape in many aftermarket heads. Where lower compression won't hurt is when running a blower or turbocharger set up. A lot of truck blocks were relieved at the factory so a person is sort of stuck with it if they have one of those. Make the best of it if that's what you have.
The decks aren't all that thick without a relief and relieving tends to make them more prone to heat cracking if the engine ever gets overheated. |
#14 |
I have been fortunate to have had 2 new 59L blocks with the factory relief. Both were bored to 3 5/16th with 4 inch Merc cranks and the Offy 400 heads. I always figured the compression ratio at close to 9to1. Both seemed to operate alright on regular pump gas. I'm not smart enough to know if the relief helped or hindered their performance?
#15 |
THEOffy 400 heads won't clear the lift of the 400jr cam. In fact neither will the 425 head, I made a fixture to clearance the head at a 4 deg angle so i wouldn't remove much material. Most of the engined I buikd back in the 90's were 276, blocks and Merc cranks were cheap and the 400 jr wa a nice cam. i went to the L-100 soon after. It was allot cheaper and didn't need much spring pressure, but the offy heads still had to be clearanced for cam lift
Most of the aftermarket HC heads had the area over the relief area lowered ito increas CR and a relief job just lowered it Massive waste of time. I started cutting my own chambers. |
#16 |
Both my 59L engines used a reground cam I got from Baxter Ford Parts that was similar to the Isky 88 cam. It's been a while but I don't remember having any clearance problems on the heads. But I could be wrong?
#17 |
This is the second one to have passed through my hands. The first one was recovered from a boat in the 1980's and the sump was full of sand. I noticed that the heads were different in the area over the piston tops. They had much more meat covering 'more' than half of the piston. I assumed this was to compensate for the loss of material from the block so as not reduce compression. I think I still have these heads in my stash. Could I bolt them onto a standard unrelieved block to increase compression? |
#18 | |
#19 |
I'll try to locate the heads and upload a pic. If they arn't here at my place then they may be at my sisters. We are currently locked down here in NZ so it may be a while. Also unsure how to load a picture here.
Regards Kevin |
#20 |
Fab link. Great info tutorial etc.. create your flow pattern maybe.. Regards Kevin
