Old 08-14-2021, 02:17 AM   #1
wagonshed
Default model A overheats
Looking for suggestions on what to do next on my "29 model A speedster. When the air temp is approaching 80 degrees the red of the temp gauge is in the gauge's circle. Temp of high 80-90's she'll boil over. Engine was rebuilt perhaps 10 years ago, newer leak proof water pump, checked timing and carb adjustment and cleaned radiator with permatex radiator cleaner twice. Don't know age of radiator, any suggestions other than replacement? Thanks
wagonshed is offline   Reply With Quote
Old 08-14-2021, 05:10 AM   #2
ronn
Default Re: model A overheats
I put vinegar in all my rads and wait 6 weeks. seems to work every time. Some guys prefer Evaporust, which works much more quickly, but 90. for a 5 gallon drum.
In any case, it shouldnt be your motor, if it was in fact rebuilt properly.
My roadster was quite stubborn. despite flushing it with vinegar, I had to go back and do it again and the "mud" that came out of it, was amazing. now running as cool as a cucumber!
Old 08-14-2021, 07:01 AM   #3
nkaminar
nkaminar's Avatar
I love my new Bergs radiator. Never boils over.
Old 08-14-2021, 07:59 AM   #4
WHN
New radiator needed. Money well spent and another item off the list of “need to do”.
Enjoy.
WHN is offline   Reply With Quote
Old 08-14-2021, 08:36 AM   #5
eagle
eagle's Avatar
Make sure you're running the spark lever properly. Pull it down until you hear it ping when pulling hard, then up a click or so, just enough to stop the ping. Most model a radiators are crudded up, if you can't get it clean replace it. You dont want to ruin your new engine.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 08-14-2021, 09:21 AM   #6
Dougs 28
Dougs 28's Avatar
Buy a Bergs radiator, they work great..!
Dougs 28 is offline   Reply With Quote
Old 08-14-2021, 09:30 AM   #7
ddweave
ddweave's Avatar
X3 on Bergs. I never have to add coolant and it never overheats.
Doug in Waterloo
ddweave is offline   Reply With Quote
Old 08-14-2021, 12:02 PM   #8
700rpm
700rpm's Avatar
You could time a draindown of the radiator which would indicate how well it flows. I can’t remember what the preferred time result is, but I’m sure someone here can give a better description of the process and desired time.
Or you might find that test procedure here: http://www.fordgarage.com/
Ray Horton, Portland, OR
Old 08-14-2021, 12:38 PM   #9
Gene F
Gene F's Avatar
wagonshed, it is almost always the radiator. I must say, I had the same symptoms with the radiator on my car after I bought it years ago. It had a Sears 2-row radiator in it.
Gene F is offline   Reply With Quote
Old 08-14-2021, 01:17 PM   #10
Big hammer
Check the accuracy of your temperature gauge, coolant level below the baffle, advance the timing with the hand lever, water with antirust added will run cooler by 20-25 degrees!!!
Guys he wants answers other than replacing the radiator.
get a bigger hammer tap done
Old 08-14-2021, 02:20 PM   #11
Stingray70
Stingray70's Avatar
Check for and remove any restrictions like a thermostat. Make sure you don't have a 2 row radiator.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 08-14-2021, 04:36 PM   #12
1crosscut
1crosscut's Avatar
First lets determine what the temperature of the coolant actually is.
Pick up an inexpensive dial meat thermometer and stick it directly into the coolant through the radiator neck.
Knowing the actual temperature rather than it's in the red is important.
By the number of posts that you have I am assuming (perhaps incorrectly) that you are new to the Model A engines.
Many new to the hobby tend to fill their radiators very close to the top and as the coolant warms up it expands and will push out through the overflow tube. This looks a lot like it is overheating when it is actually not.
You do not need to or want to "fill" your radiator. Just keep an eye on the coolant level and resist the urge to put more in as long as the top of the tubes in the radiator remain covered with coolant. The engine will push out excess coolant until it finds the level it is comfortable with.
As far as coolant it is hard to beat a 50/50 mixture of coolant and distilled water.
It is possible that you have a head gasket that is leaking. At temp and under load blow by can push water out too.
Have you checked the torque on the head nuts?
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 08-14-2021, 05:59 PM   #13
Gene F
Gene F's Avatar
Yes, if you get bubbles in your radiator you have a head gasket that is seeping combustion gasses into the water jacket. And that surely will heat things up.
Old 08-14-2021, 06:00 PM   #14
TerryH
TerryH's Avatar
If you have a lot of tubes in your radiator really plugged, vinegar or other solutions will likely not clear……the only sure way to unclog them is to have it rodded, by someone who knows how to do it. My radiator had over 20 tubes totally plugged, had it rodded, and all but a few were cleared…..no more overheating!
TerryH is offline   Reply With Quote
Old 08-14-2021, 06:27 PM   #15
Synchro909
Synchro909's Avatar
http://liquidintelligence.com.au/pro...m-cleaning-kit and read and believe what they say about cleaning out the cooling system. A kit is enough for 2 Model As so maybe you could share. Remember, the prices are in Australian dollars so it would be about 3/4 that number in US dollars.
My brother in law has used it and we couldn't believe the results.
I have no association with the company.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 08-15-2021, 04:16 AM   #16
wagonshed
Thanks for all the great replies, I now have a number of new things to verify, sometimes half the problem is just knowing what to do.
Old 08-15-2021, 11:47 AM   #17
J Franklin
J Franklin's Avatar
Synchro909, thanks for the link, it is an interesting product and a great site with a lot of info.
Old 08-15-2021, 03:23 PM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
LOL so true, but the radiator might be the only fix. Try cleaning it first. I cleaned my original 1928 radiator by running with vinegar for a month. It made quite a mess, but did clean it.
Old 08-15-2021, 03:43 PM   #19
Ernie Vitucci
Ernie Vitucci's Avatar
Good afternoon Tom...How much Vinegar did you use in the system? Mixed with water or was it all vinegar? Thanks, Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 08-15-2021, 04:22 PM   #20
Tom Wesenberg
Ernie,
I use 2 gallons of vinegar, which as I recall was about 5% acid. The vinegar took the off the grease on the lead packing seals and made the original water pump leak and make a mess all over my engine. I cleaned it with diesel and WD-40. If my water pump would have had the double lip seal, it probably wouldn't have made the big mess, so now I use the seal for added protection on my water pumps.
I bet doing a search for "Tom Wesenberg engine mess" will turn up pictures of it.
