Old 07-06-2021, 02:36 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default KR Wilson spring spreader
Looking for a KR Wilson, or equivalent, spring spreader. Does anyone have one for sale? Send pictures to Lawson Cox, direct email, [email protected].
Old 07-06-2021, 02:46 PM   #2
19Fordy
19Fordy's Avatar
Default Re: KR Wilson spring spreader
Any chance of posting a photo of what that tool looks like?
Would be neat to see.
Old 07-06-2021, 04:21 PM   #3
Don Rogers
Don Rogers's Avatar
Here it is!!
Don Rogers is offline   Reply With Quote
Old 07-06-2021, 05:28 PM   #4
mercman from oz
mercman from oz's Avatar
KR Wilson Spring Spreader.
Old 07-06-2021, 05:36 PM   #5
mercman from oz
Here is an alternative Spring Spreader, the Litchfield Spring Spreader - Made in Australia.
Notice the Instructions inside the Lid that lists what Combinations are needed for what vehicle, including the small British Ford Prefect and Anglia.
Old 07-06-2021, 05:47 PM   #6
mercman from oz
Old 07-06-2021, 06:04 PM   #7
mercman from oz
Another type of early Ford Spring Spreader.
Old 07-06-2021, 06:23 PM   #8
19Fordy
19Fordy's Avatar
Wow, Thanks for posting all those photos. I can see why it's such a desirable tool.
If you ever locate a really big turnbuckle you can make one like this.
Old 07-06-2021, 08:36 PM   #9
doghair3
If your in a bind you could get this one here.
https://www.ebay.com/str/macsfabrica...pring+Spreader
doghair3 is offline   Reply With Quote
Old 07-06-2021, 08:51 PM   #10
Lawson Cox
Lawson Cox's Avatar
This is the spring spreader I actually had in mind, and have used one like it several times. I like it very much. Does anyone have a Litchfield spring spreader they would part with?
Thanks
Old 07-06-2021, 11:55 PM   #11
deuce lover
deuce lover's Avatar
I have a old Snap On that I found in a closed out shop.I think its from the 30's.The adapter pipes on one end were lost in shipment so made those up
deuce lover is offline   Reply With Quote
Old 07-07-2021, 05:47 AM   #12
jimTN
I use a porta power that has the correct ends in the kit. I think Northern Hyd and Harbor Freight carry those kits. Put the curved ends on pipes with the hyd jack in the middle and pump away.
jimTN is offline   Reply With Quote
Old 07-07-2021, 06:12 AM   #13
russcc
The best one I have used is the early Snap On. Works smooth as glass, and strong as a bull. If I were to to compare the Snap On to the KR Wilson, the Snap On is simple and a far better design and execution.
russcc is offline   Reply With Quote
Old 07-07-2021, 07:25 AM   #14
37 Coupe
37 Coupe's Avatar
I have been looking for one for quite awhile. I ran parts wanted ads both on Fordbarn and Early V8 Club classified to no avail other than the guy from England that will part his car out to get me one.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 07-07-2021, 09:43 AM   #15
Terry,OH
Terry,OH's Avatar
The K R Wilson spreader as shown in post #4 above will only do the rear spring due to it's over all length. K R W had a associated tool that used in conjunction with their spreader would do the front spring.
Old 07-07-2021, 09:44 AM   #16
JSeery
JSeery's Avatar
Originally Posted by 37 Coupe View Post
... other than the guy from England that will part his car out to get me one.
That would be interesting!
Old 07-07-2021, 10:02 AM   #17
Robz51
Robz51's Avatar
Didn't Mart make one of these?
Sent from my SM-G955U1 using Tapatalk
Robz51 is offline   Reply With Quote
Old 07-07-2021, 10:13 AM   #18
Krylon32
I've got a home made rear spring spreader that my great uncles used in their Ford dealership in the 30's and 40's. It a length of 1 inch ready bolt that slips into some heavy wall tubing with a heavy flat washer welded on 1 end of the tube and the other end smashed flat to a point to wedge in the spring. The ready bolt has a big square nut for adjustment that tightens against the washer with the end of the ready rod also ground flat to fit into the spring. Easy to make of you had access to the materials. I've used it dozens of times over the years in my shop. 30's technology.
Krylon32 is offline   Reply With Quote
Old 07-07-2021, 10:48 AM   #19
Yoyodyne
Yoyodyne's Avatar
I was going to try that myself. Does the HF portapower have plenty of travel for the job?
Yoyodyne is offline   Reply With Quote
Old 07-07-2021, 11:43 AM   #20
HemiDeuce
HemiDeuce's Avatar
[ATTACH]E5C3B624-5732-49F1-B939-3506802ADC29_1_105_c.jpg[/ATTACH
I built this one to clear the Quick Change.
File Type: jpg 3969E1B0-DB93-4262-B46E-A58E7E9EBB33_1_105_c.jpg (56.1 KB, 164 views)
HemiDeuce is offline   Reply With Quote
