Old 07-04-2021, 05:03 PM   #1
shew01
shew01's Avatar
Default Leaky Tire
Last summer, I noticed a cracked rim, and I bought a used wheel to replace it. I had the used wheel power coated, and I swapped the old tube and tire to the “new” wheel. It was the first time I ever replaced a Model A tire; so, I’m certainly no expert on this task. Unfortunately, the tire tube has leaked ever since.
If you break the “seal” on an installed tube to move it to a new wheel, should you be able to reuse the tube? Please see picture of valve stem.
shew01 is offline   Reply With Quote
Old 07-04-2021, 05:48 PM   #2
700rpm
700rpm's Avatar
Default Re: Leaky Tire
I have (too often) punctured an innertube with tire irons either during removal or remounting the tire. That may have happened with you too. I’ve never had original metal stems though, so I can’t speak to whether they are prone leakage.
I also check the innertube by pumping it up and exposing it enough to water that any small leak might hiss and bubble, before I reinstall. When I was 17 (1962) I worked in a service station that had a Model A pickup as a service vehicle, and was taught to mount half the tire first, then partially inflate the tube, position the stem, then finish the mounting. Partially inflating the tube reduces the risk of pinching and puncturing it with tire irons.
Ray Horton, Portland, OR
Old 07-04-2021, 09:14 PM   #3
shew01
shew01's Avatar
Is the tube likely to make a mess in the bathtub if I try testing it there?
Old 07-04-2021, 09:40 PM   #4
McMimmcs
McMimmcs's Avatar
It’s called pinching. Put a little soap and water in a spray bottle and spray the inflated tube, look for the bubbles, then mark the pinch X with a ball point pen.
McMimmcs is offline   Reply With Quote
Old 07-04-2021, 09:52 PM   #5
J Franklin
J Franklin's Avatar
Make sure the valve isn't also the leak before you tear things down.
Old 07-04-2021, 10:35 PM   #6
warrene
Don't fool with damaged tubes, ordrer a new one from Snyder's. The best way to put a tire together is to have your tube in place, I usually put a close fitting washer over the stem, then add a cap to hold it, they way you wont lose the stem.
Get it together all you can by hand, then use a hammer to get the rest of the bead over and on, this way ther are no tools pinching the tube and making a bad spot.
warrene is offline   Reply With Quote
Old 07-05-2021, 12:16 AM   #7
pbishop
Ditto for replacing the old tube. You have gone to a lot of effort to replace the wheel, so do the same with the inner tube. Penny wise - dollar foolish as an old Triumph tech told me years ago when I owned Triumphs.
Also, you should put a little oil on the tools you are using and on the beads of the tire to make things slide on easier. Take your time and do not rush your effort. Make sure you are not pinching the inner tube during installation (as someone noted already).
pbishop is offline   Reply With Quote
Old 07-05-2021, 06:20 AM   #8
shew01
shew01's Avatar
Default Leaky Tire
The tube looks new. Is it really necessary to replace a good tube when moving to a different wheel? This isn’t a matter of “cheaping out.” I have a spare new tube on hand, but I don’t want to throw away a good part if it isn’t necessary.
Old 07-05-2021, 06:26 AM   #9
shew01
shew01's Avatar
Good idea.
Old 07-05-2021, 06:29 AM   #10
shew01
shew01's Avatar
Default Leaky Tire
For me, that may be a better plan than potentially making a mess in the bathtub.
Old 07-05-2021, 07:31 AM   #11
ModelAMike1930
ModelAMike1930's Avatar
I would suggest bringing it to a professional tire store that is used to mounting tires with an inner tube. I had both of my model as done with my new tires.
ModelAMike1930 is offline   Reply With Quote
Old 07-05-2021, 08:21 AM   #12
marty in Ohio
marty in Ohio's Avatar
Shew, to answer your original question, there is no reason that you can't reuse the old tube. Just blow it up and make sure there's no holes in it. I usually dunk it in a washtub and watch for the bubbles. When I put it all together I put Murphy's Oil Soap on the tire and the rim. It makes it slippery and washes off easily. Also, I don't use tire irons. I've made tools out of hardwood. They're much gentler on tubes. Good luck.
Marty
marty in Ohio is offline   Reply With Quote
Old 07-05-2021, 10:07 AM   #13
Y-Blockhead
Y-Blockhead's Avatar
Marty
Marty, I love homemade tools. Can we see some pictures of your "Tire Hardwoods"? I bet they are much gentler on the wheels as well.
Old 07-05-2021, 10:30 AM   #14
Ed in Maine
Hello Shew, you have a lot of good ideas above. To summarize:
1. Do not take the tire to a professional garage. With Model As there are very few professionals, most have all passed away. The old timers and we the owners are the professionals now keeping these cars on the road. Garages will be just great removing the paint around your rims.
2. Do not use tire irons. Watch a Youtube video and see some the tricks they use such as a large trash bag which is very slippery!
3. Put soap and water on the valve stem to see if the inner valve is leaking.
4. Have someone help you during the mounting process, preferably someone who is big.
5. Following procedures you have seen on Youtube, lubricate the rim and tire and have your big friend walk around the tire and use wooden sticks to keep the tire from poping back off as he goes around.
I find this job somewhat amusing because you can make it incredibly difficult or extremely easy. Hopefully when you are done you still have all your paint and it doesn't leak. Good luck, Ed
Ed in Maine is offline   Reply With Quote
Old 07-05-2021, 02:34 PM   #15
shew01
shew01's Avatar
Thanks for the help. However, it looks like the leaky tire is a moot point for now. I measured the tread depth, and it needs replaced.
Old 07-05-2021, 03:14 PM   #16
J Franklin
J Franklin's Avatar
How often do you drive in a rainstorm where you might hydroplane?
Old 07-05-2021, 05:19 PM   #17
700rpm
700rpm's Avatar
"1. Do not take the tire to a professional garage. With Model As there are very few professionals, most have all passed away. The old timers and we the owners are the professionals now keeping these cars on the road. Garages will be just great removing the paint around your rims."
I second that. Modern shops know how to work on modern cars. 90-yr-old painted spoked wheels are not their bag. In fact, I would expand that and say don’t take your Model A to any modern mechanical or electric work shop either. These cars require service from and by people who know Model A’s.
Old 07-05-2021, 05:33 PM   #18
Fred K OR
Sometimes if you have the tube out, you can blow it up quite a bit, wet it down and you can hear where the leak is.
Fred K OR is offline   Reply With Quote
Old 07-05-2021, 05:33 PM   #19
Fred K OR
Hi Ray, how you doing?
Old 07-05-2021, 06:48 PM   #20
shew01
shew01's Avatar
Default Leaky Tire
It’s rare that the car gets caught in the rain. If it rains, the car normally stays parked. Skinny little (new or old) tires are not that great in the rain.
I started to place an order for new radials with Coker, but the site says they are back ordered.
Has anyone had a back order filled with Coker? Does a back order typically mean days or does it mean months?
