Old 06-29-2021, 09:13 PM   #1
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Default More transmission woes
Tranny for my '36 pickup, a 78- case(1939) with early gear set,behind stock babbitt-bearing motor, never abused, rebuilt about 9000 miles ago and worked perfectly, then in November broke two teeth off the reverse idler gear and two of the caged bearings failed. Rebuilt with good used caged bearings from MacVP, new cluster gear shaft and good used reverse idler gear-now after 1000 careful miles, a broken tooth on the low speed gear of the cluster shaft-all else looks fine including the caged bearings. The cluster gear was a new aftermarket item at the first rebuild(I believe from India, via MacVP). The low gear on the mainshaft really looks OK.
My question: The only issue I noticed during the rebuild was that the cluster shaft was basically a finger-pressure slip fit in the case, I assume from wear over the years. Is it possible this allowed some "monkey motion" between the cluster gears and the mainshaft gears, leading to the failure? Or any other ideas?
I'm getting entirely too good at R+R'ing this transmission!
Thanks,
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 06-30-2021, 08:50 AM   #2
Charlie ny
Default Re: More transmission woes
Adam,
I read that the 1st and rev slider gear is good bur 1st gear on the cluster
has the broken tooth............check your PM's
Charlie ny
Charlie ny is offline   Reply With Quote
Old 06-30-2021, 09:11 AM   #3
Terry,OH
Terry,OH's Avatar
.005-.017" is the normal range of clearance on the cluster thrust. .025" is the wear limit. There are other clearances that need to be kept. Consult Mac VanPelt rebuilding book if you don't have one It can be a worth wile purchase!!
Old 06-30-2021, 09:20 PM   #4
Adam/Mill Valley CA
Charlie, see my PM to you
Terry, I used a new rear thrust washer with the cluster and the axial clearance looked good when I assembled it, my question was whether there was excessive play in the radial direction between the cluster and the mainshaft gear especially when under load. I do have MacVP's book (and use it), it is a terrific resource
Adam
Old 07-01-2021, 12:36 PM   #5
svm99
I'd be suspect of the end play on the cluster gear, I do a dry fit with all related parts clean, drop the cluster in the case with the 2 thrust washers and measure the end play. Not all rear thrusts are the same thickness, new vs NOS vs NORS. I measure each thrust I have to either increase or decrease end play as required to get it into the Ford spec of .005"-.017" end play. Also, the tooth shape on the reproduction gears does not seem to have the same profile as the Ford gears, especially on the leading edges where 2 gears engage, seems to be less rounded and a bit more vertical in shape than the original Ford. Many of the aftermarket gears of the day have this issue as well, especially on the low/reverse slider and reverse idler. Check your parts closely, especially for very small chips in the low/reverse slider.
svm99 is offline   Reply With Quote
Old 07-01-2021, 07:56 PM   #6
Adam/Mill Valley CA
svm99, I'll certainly look at these things closely
Thanks,
Adam
