Old 06-21-2021, 01:49 PM   #1
terryb270
Default Clam shell cover over spare tire.
Just got a 36 Humpback, and really not sure how to remove the clamshell covering the spare tire on the back of my Humpback. What is the trick so that I don't screw up a $300.00 part? Thanks for any help, I'm a lost ball in high weeds with this thing.
terryb270 is offline   Reply With Quote
Old 06-22-2021, 12:01 AM   #2
Will D
Will D's Avatar
Default Re: Clam shell cover over spare tire.
Welcome aboard terryb270. Congrats, nice '36 humpback. Not sure how to get your spare tire out but someone will chime in with the know how.
Sometimes, ingenuity gets in the way of sense and sanity.
Will D is offline   Reply With Quote
Old 06-22-2021, 11:00 AM   #3
TJ
TJ's Avatar
Originally Posted by terryb270 View Post
Just got a 36 Humpback, and really not sure how to remove the spare time mounted on the back of my Humpback. What is the trick so that I don't screw up a $300.00 part? Thanks for any help, I'm a lost ball in high weeds with this thing.
Did you lift the hub cap on the spare to see if there is a lock mechanism in the center? the outer ring holds the center plate in place. The outer ring that covers the tread needs to come off first. if the center plate has a lock you may need a key to remove it. If no key or lock it may come off. If locked and the key is missing that becomes a problem.
Old 06-22-2021, 11:15 AM   #4
Lawson Cox
Lawson Cox's Avatar
To remove the outer ring you simply grab ahold of the loop at the bottom of the outer ring and pull it down and out towards you. The rubber ring around the faceplate, in theory, protects the faceplate when you pull the outer ring off as described. Good luck.
Old 06-22-2021, 01:35 PM   #5
VeryTangled
VeryTangled's Avatar
Welcome to the Forums terryb270!
One technique is to not fuss with the trim ring and center dish while it's on the car.
Get the lug nuts off and the whole assembly in a more manageable place.
Deflating the tire might help.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 06-22-2021, 03:45 PM   #6
Lawson Cox
Lawson Cox's Avatar
Hey Very Tangled. You have to get the spare tire cover off of the spare to get to the lug nuts. Duuuhh.
Old 06-22-2021, 05:00 PM   #7
mercman from oz
mercman from oz's Avatar
Remove the outer rim first, then pull down the hinged hubcap to reveal the lock. Use key and this cover will come off leaving the spare wheel held onto the mount with three lugs. Hope that this helps.
mercman from oz is online now   Reply With Quote
Old 06-22-2021, 05:04 PM   #8
mercman from oz
1936 Ford Spare Wheel Cover with the hinged Hubcap lowered to reveal the Lock.
Old 06-22-2021, 05:17 PM   #9
DavidG
DavidG's Avatar
Tom,
On a '36 the center section is held in place by the lock, not by the outer ring, unlike the previous model years' versions.
Old 06-23-2021, 09:06 AM   #10
terryb270
Thanks, everyone, I didn't want to damage the clamshell, by just yanking it off, but apparently, that's what you do.
Old 06-23-2021, 09:32 PM   #11
Voycey
Voycey's Avatar
Hi A shot from the back showing the lugs , dont force the key , maybe spray crc down the lock , once you have the outer surround off , carefully pry the front enough to get some spray down on the lugs as they do get seized up at times. Good luck
Voycey is offline   Reply With Quote
