Old 06-11-2021, 11:55 PM   #1
Fatheads4ever
Fatheads4ever's Avatar
Default Ford V8 crankshaft removal
Hi All.. just trying to lift out my v8 crank with the fly wheel and clutch pressure plate attached but it seems to catch on something at the bell housing end. Any ideas on what coild be the issue?
Regards Kevin
Fatheads4ever is offline   Reply With Quote
Old 06-12-2021, 01:51 AM   #2
bbrocksr
Default Re: Ford V8 crankshaft removal
Regards Kevin
Front of flywheel catching on oil pump drive gear cover? remove flywheel.
Bill
bbrocksr is offline   Reply With Quote
Old 06-12-2021, 01:52 AM   #3
Brian
Brian's Avatar
Remove the clutch and flywheel ,then the crank will come
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 06-12-2021, 05:13 AM   #4
Fatheads4ever
Thanks Bill.. I was trying to avoid taking off the flywheel but I guess I'll have to do it.
Old 06-12-2021, 05:15 AM   #5
Fatheads4ever
Thanks Brian.
Old 06-12-2021, 09:55 AM   #6
flatjack9
flatjack9's Avatar
If the crank even tilts slightly, it will wedge on the thrust bearing edges.
