06-08-2021, 07:30 PM | #1 |
Brake lights
So on to my brake light issue. When pressing on the brakes, only the yellow part lights up. I can't get anything on the red part to light up. The car also came with this strange license plate that that wags back and fourth. That does work. Any ideas?
06-08-2021, 08:21 PM | #2 |
Re: Brake lights
The yellow is the brake light the red is tail light.
06-08-2021, 09:12 PM | #3 |
Re: Brake lights
06-08-2021, 09:17 PM | #4 |
Re: Brake lights
You can replace the lens with an all red one.
06-08-2021, 09:35 PM | #5 |
Re: Brake lights
I often recommend that folks add an LED brake light in the rear window. Not original, but a much more functional cue to modern drivers and you can leave the original brake light as is. They can also be wired to double as turn signals.
06-09-2021, 07:16 AM | #6 |
Re: Brake lights
06-09-2021, 08:05 AM | #7 |
Re: Brake lights
Your yellow lens will light up red with a red LED behind it. Use a bright one. (Or two). Some places require red brake lights. The bulbs cost about the same as new lenses, and you stay original, fwiw.
06-09-2021, 08:19 AM | #8 |
Re: Brake lights
I got a ticket in California many years ago for a yellow stop light on a Model AA truck. I went to court to show that it was original equipment and the judge dismissed the ticket. I think the cops just wanted to get my truck off the highway. It was an original farm truck and looked the part including bullet holes going out from the riffle that the farmer would store behind the seat.
06-09-2021, 08:39 AM | #9 |
Re: Brake lights
What you described might be the "WigWag" stop signal brake light. They were on Studebakers as an option beginning in 1936. I think it was a $5.00 item or $6.00 dealer installed. Patent applied for in 1931 by Safety Signal Inc. in Chicago and made by Dua-Saf.
06-09-2021, 09:02 AM | #10 |
Re: Brake lights
06-09-2021, 10:03 AM | #11 |
Re: Brake lights
Here is a pic of the wagging thing. I just left it on
06-09-2021, 10:20 AM | #12 |
Re: Brake lights
THANKS FOR YOURREPLY ALEXISKAI . II HAS TAKEN ME A FEW MINUTES TO LOG IN.
THANKS FOR THE PHOTO KURSED30. THAT EXPLAINS WHAT YOU HAVE. THIS LINK IS WHAT I WAS THINKING OF. https://jalopnik.com/holy-crap-this-...e-b-1846300362 |
