06-03-2021, 09:58 PM | #1 |
Flywheel bolts
I am having a bit of trouble, I have run a FoMoCo 4 speed for a few years but I got a new clutch plate and the Springs hit the flywheel bolts by about 0.5,
Is there any other low profile bolts that would work with a flathead? |
06-03-2021, 10:58 PM | #2 |
Re: Flywheel bolts
Can I use the low profile ARP bolts with out the lock wire? I still need to keep that plate to hold the dowl pins in
06-04-2021, 02:14 AM | #3 |
Re: Flywheel bolts
chuck em in a lathe and cut em off
06-04-2021, 02:37 AM | #4 |
Re: Flywheel bolts
I need to take about 3 mm off them, it would brake thrugh the lockwire holes and make a mess
06-04-2021, 03:21 AM | #5 |
Re: Flywheel bolts
Sounds like you may have clutch disc in backwards. The springs go out towards gearbox.
06-04-2021, 03:59 AM | #6 |
Re: Flywheel bolts
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver |
06-04-2021, 07:02 AM | #7 |
Re: Flywheel bolts
I ran into a similar clearance issue with my new steel flywheel and aftermarket clutch. I was reluctant on grinding down flywheel bolts, so contacted ARP and bought bolts that have a reduced head height. Also removed the flathead flywheel locating dowel retainer that gained over .050". Just lightly stake the flywheel dowel holes to prevent any movement. Overall gain was over .100" that resulted in the extra spring clearance I needed.
06-04-2021, 07:22 AM | #8 | |
Re: Flywheel bolts
06-04-2021, 02:32 PM | #9 |
Re: Flywheel bolts
I am using a mitsubishi clutch plate witch has a bigger marcel, the FoCoMo 4 speed has a fine spline input shaft
06-04-2021, 02:33 PM | #10 |
Re: Flywheel bolts
Is it ok to run the ARP bolts with no lock wire
06-04-2021, 02:46 PM | #11 |
Re: Flywheel bolts
I never run the lock wires, I just torque em up with loctite. Never yet had a flywheel come loose.
06-04-2021, 03:01 PM | #12 | |
Re: Flywheel bolts
I had a flywheel come loose on a BMW and when it did it sheared off all 8 bolts anyway, funny thing is I was able to drive home and then I toched the throttle and the engine reved up so fast it clipped the valves on the piston and starter motor just turned the flywheel and not the engine. |
06-04-2021, 03:58 PM | #13 |
Re: Flywheel bolts
What Brian said & yes punch flywheel to retain dowels
06-04-2021, 08:45 PM | #14 |
Re: Flywheel bolts
I will go and see if I can find a set after the long weekend
06-07-2021, 06:47 PM | #15 |
Re: Flywheel bolts
I got some low height ARP flywheel bolts witch look good they have a nice wide head witch is lower.
How meany lbs should I tighten them to? I am going to use some locktite and leave that steel plate out |
06-07-2021, 07:22 PM | #16 |
Re: Flywheel bolts
65 ft/lbs...torque in three stages
06-08-2021, 08:27 AM | #17 | |
Re: Flywheel bolts
The ARP bolts I bought were #P10AP.750-1. ARP torque specs are: 70 ft.lbs with ARP moly. 75 ft/lbs with 242 Loctite. (what I used) 85 ft.lbs with 30W oil. Always follow ARP torque specs when using their bolts. The flywheel bolt holes required a very slight chamfer to ensure full bolt head contact, per ARP. Last edited by V8 Bob; 06-08-2021 at 08:53 AM. |
