#1 |
When installing the glass in rear doors I found the riser arms popping out of the metal channel on the bottom of glass. Can I just get a wood block and tap this metal channel about 1" left or right OR is there another/correct way to move this without breaking glass. Thanks
#2 |
You could tap it left or right, but keep in mind that the glass channel setting tape may not move with the channel.
#3 |
