#1 |
Does someone have a diagram -sideview looking into each side of distributor- showing placement of plug wires into cap? I want to be correct fist time, no do overs. I have a persistent miss in motor trying to track down. Tanks in advance!! Steve
#2 |
Does this help?
#3 |
The brass high tension plug wire sockets are numbered in the plastic for either right or left cylinder bank plugs. You really cant get it wrong, can you? Regards, Kevin.
#4 |
Kevin,
Some of the aftermarket caps do not always have this feature. Graham |
#5 |
