#1 |
What is it, never have seen before, what do you guys know about it.....??
#2 |
Let’s see it or we probably won’t know a thing.
#3 |
I still don't know what it is . . . can anybody clarify?
#4 |
Brass? Part of a marine conversion?
#5 |
I've a n.os. single alum water pump somewhere in my barn, not certain if o.e.m. or not always watched for the opposite side at swap meets to no avail. I believe Speedway & possibly others stocked a repo version at one time.
#6 | |
Super Moderator
Aluminum (authentically) was used on some aircraft.
#7 |
Speedway Motors does offer aluminum 8BA pumps : https://www.speedwaymotors.com/1949-...mps,57412.html
#8 | |
True scoop, Kube! The Ford "15P" (actually "Stout Metal Aircraft Co.") had an all aluminum Ford flatty. Notice that the "right" & "left" heads are swapped side for side. DD ![]()
