Old 05-10-2021, 01:58 PM   #1
David J
David J's Avatar
Default FL&WV Mikes 34 phaeton update .
Put enough miles on that a brake adjustment was in order .
Pulled floorboard and tranny cover to have better access and give it a general going over .
Never asked Mike so the tranny matching frame and title was a pleasant surprise .
Changed the speedo cap from a 21 to a 18 and now the speedo reads 59 at actual 60 .
MUCHO BETTER as it used to read way slow .
Brakes required only adjusting as Mike had all that stuff in very good order
. Still has STP he ran in the steering gear and I am leaving it as it works fine .
Put the NOS windshield frame that I got with it on and a nice set of top irons .
Keeping all the replaced stuff of course and may eventually get them re-plated .
Thinking about taking the REDS HEADERS and Smitty mufflers along with the dual exhaust off as I like quiet cars .
With no Joblot anymore where do you get stock pipes now ?
I have a NORS muffler that came with the car that I will use .
Looking for top bows and a header for this car and also need same for a 34 roadster .
Sorry bout the rambling but I am still a giddy little kid over finally getting this car .
Asked Mike many times and he just laughed at me .
Still missya bud and RIP !!
David J
Added a couple pics with side curtains on .
Visibility is not good and they are a little shrunk up .
Been looking into stretching them a little and old military stuff collectors tell me putting pressure on them and setting them in bright sunlight for 15 minutes.
Then soak them down and when they relax put a little more pressure on and let the sun dry them .
Sun is evidently for the window parts so they don't just crack-split .
Sounds like it has hope but will try on old tent material first .
David J is offline   Reply With Quote
Old 05-10-2021, 02:16 PM   #2
VeryTangled
VeryTangled's Avatar
Default Re: FL&WV Mikes 34 phaeton update .
This is one of the really cool cars still out there!
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 05-10-2021, 02:23 PM   #3
David J
David J's Avatar
Thanks Jeff and I REALLY LIKE IT !!!!!
Not the same without Mike in it with me but I do still have the memories ! ADDED pic before repairs started . Dark when done so no after pic yet .
Last edited by David J; 05-10-2021 at 02:32 PM. Reason: added pic before working on it
Old 05-10-2021, 08:41 PM   #4
VeryTangled
Here's another...
-Jeff H
Old 05-10-2021, 08:52 PM   #5
mercman from oz
mercman from oz's Avatar
Mike's 1934 Ford Phaeton was one cool unrestored car as you can see in this picture.
I am glad that it has gone to an appreciative new owner.
Old 05-10-2021, 08:58 PM   #6
mercman from oz
Here are the original Window Linings for your 1934 Ford Phaeton.
Old 05-10-2021, 11:50 PM   #7
cas3
Really nice David, hope to get up for a ride this summer. Two years ago when I needed stock exhaust for my tudor the only thing I could find available was from macs. Too bad they sent me exhaust pipes for a 49 plymouth...or sumthin, cause it sure was a lot of cutting, bending, and welding to install. Hope someone has a better Idea.
Old 05-11-2021, 12:58 AM   #8
David J
David J's Avatar
Talking Re: FL&WV Mikes 34 phaeton update .
Thanks to all and c'mon up Clayton - you know the way .
I am in no way up to Mikes level as he was a really good guy .
Me not so much but I am looking after his car and I assumed some would be interested in how it is doing .
Old 05-11-2021, 04:17 PM   #9
JMFL36
JMFL36's Avatar
Here's mine. Same color? I am looking for a set of side curtains and irons if anyone has some laying around.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 05-11-2021, 04:35 PM   #10
VeryTangled
JMFL, Side curtains are really best made to the car, tailored as it were.
Irons, if you get them will still need optimization because of pocket stability and iron curves/deviation.
David J's, previously Mike's 34, is way special because it's, well, not so 'showroom.'
-Jeff H
Old 05-11-2021, 04:51 PM   #11
JMFL36
JMFL36's Avatar
VeryTangled, I'm familiar with Dave/Mike's car and agree its special. And I certainly don't want to hijack his thread. I was able to find a set of Roadster side curtain irons, and I have a copy of the original drawings of the rear irons that I bought from the Benson Ford Research Center at The Henry Ford. I really just need to borrow a set of old curtains to use as patterns for new ones. Mike was kind enough to send me pictures of his curtains before he sold the car. But having old curtains on hand would probably be better than pictures. BTW, mine was restored 25 years ago and is a weekly driver.
Old 05-11-2021, 05:31 PM   #12
VeryTangled
JMFL36, I have a '36 Phaeton with rods and curtains, please PM if I can help your project.
-Jeff H
Old 05-11-2021, 08:22 PM   #13
David J
David J's Avatar
Jeff is right about custom fitting them .
Mine need a stretch job as all buttons cannot be snapped .
Are the 4 per side studs in the top irons there ? Those are for the long upper curtain . Youcan see them in my first 2 pics .
If a safe way of doing it can be arranged these would be helpful as patterns -
just be sure to allow for the shrink factor and fit the button spacing to your car ..
Old 05-11-2021, 10:39 PM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
David J, I'm definitely interested in reading and seeing pictures of what's going on with your Phaeton that was previously owned by Mike. I went down to West Virginia to look at that car, and Mike's son gave us a ride around town in it with the top down. I thought it rode very well.
I would have loved to have had the opportunity to purchase Mike's '35 Cabriolet.
John
Old 05-12-2021, 05:27 PM   #15
David J
David J's Avatar
John ,
Will do and it is still Mikes car in my mind .
Mike was a very special guy and I for one still miss him .
I think it drives-rides very well myself .
Mike sure knew how to maintain these .
Yes on the 35 convert .
I was always drooling on " Ole Blue " though so I never got a ride in it .
Sure was NICE !!!
Before my time my dad had a 35 convert he courted my mom in .
Traded it in on a new 1950 V8 sedan .
He had the 50 for 9 years and I remember it well .
David J
Old 06-20-2021, 10:31 AM   #16
David J
David J's Avatar
Pics from yesterday . First 2 pics are interstate park on the St . Croix River and the last pic is after I got home and finally put the NOS rr fender on . The NOS windshield frame is on the car now also . Probably not going to put the lr fender on as the one on the car is very good . The rr fender was the worst part on the car and is a big improvement .
File Type: jpg resized mikeys tub interstate park 2.jpg (87.4 KB, 98 views)
Old 06-20-2021, 11:52 AM   #17
cas3
Where's the "like" button?
Old 06-20-2021, 12:06 PM   #18
David J
David J's Avatar
Hey Clayton ,
I can't find it either !!!
Anywayz how's the leg ?
How's the coupe ?
That park is only 7 miles away so when you get here you can drive the Mikeymobile there if you are so inclined . A fellow barner wants the reversed eye rear main leaf so it is time to remove it and the 3 extra leaves this week . Should soften the rear ride a little .
Old 06-21-2021, 08:24 AM   #19
Terry,OH
Terry,OH's Avatar
Like
Old 06-21-2021, 05:33 PM   #20
fordv8j
fordv8j's Avatar
glad you got your dads cars, and enjoying them, Mike was a good friend, you should attend a national meet with them,,,James RParsons
fordv8j is offline   Reply With Quote
