Old 04-22-2021, 05:56 AM   #1
russcc
Default What does this intake manifold fit ?
Is this intake manifold an early Lincoln V-12 or even a Ford product ?
russcc is offline   Reply With Quote
Old 04-22-2021, 12:26 PM   #2
petehoovie
petehoovie's Avatar
Default Re: What does this intake manifold fit ?
Old 04-22-2021, 12:36 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Yes, it is a V-12 intake, even though the runners make it look like an EIGHT cylinder intake. Check the 8 intake ports atop the V-12 block. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-22-2021, 12:38 PM   #4
Lawson Cox
Lawson Cox's Avatar
That's a long sucker. LOL
Old 04-22-2021, 12:39 PM   #5
ford38v8
ford38v8's Avatar
oops!
Alan
Old 04-22-2021, 12:53 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
That's what she said. DD
T5 W/TORQUE TUBE
Old 04-22-2021, 03:46 PM   #7
1952henry
1952henry's Avatar
Classic signature...
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-22-2021, 07:10 PM   #8
russcc
Thank again V8. What confounded me was the 8 ports for a V-12. I can see how the ports are siamesed. The photo of the V-12 engine cleared that right up. A picture is worth lots guesswork. Is this manifold an early one, as I believe I have seen other V-12 manifolds that looked different.
Old 04-22-2021, 07:49 PM   #9
51 MERC-CT
51 MERC-CT's Avatar
Ya! its a little shorter than the one that goes on this rare V14 Lincoln.
Old 04-22-2021, 08:12 PM   #10
V8COOPMAN
V8COOPMAN's Avatar
I would have been quite disappointed, had you decided not to show-up! Love it!! DD
T5 W/TORQUE TUBE
Old 04-22-2021, 08:35 PM   #11
tubman
tubman's Avatar
Just curious guys; how much does it cost to have one of them V-14's balanced?
Old 04-22-2021, 08:43 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
For you "non-believers" out there, these V-14s are not all that rare.
To answer the "tubman's" question, balancing probably ain't cheap 'cause of the extra math involved. DD
T5 W/TORQUE TUBE
Old 04-22-2021, 09:07 PM   #13
Zeke3
Zeke3's Avatar
It is amazing that one little two barrel carb can mix enough fuel and air for all those cylinders.
Zeke3 is offline   Reply With Quote
Old 04-22-2021, 10:43 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Not really when you think about a 283 Chevy, for instance, or even a 307 Chevy V-8 with 2 bbl. carbs. The Lincoln V-12 was a "mighty" 267 cu. in.....ONLY 12 inches bigger than a 255" Merc. DD
T5 W/TORQUE TUBE
Old 04-23-2021, 06:17 AM   #15
tubman
tubman's Avatar
Yeah, but Ford engineers decided the Merc needed a bigger carb. You would think they would have wanted a larger one for this as well. Perhaps nothing suitable was available at the time. I had a Stromberg at one time that had "LZ" on it rather that "97"' was that a larger carb?
Edit : As to the 283's and 307's; they have Rochester 2G's that flow at least twice as much as a 94 or 97.
Old 04-23-2021, 06:39 AM   #16
mfirth
What a neat mill....i want one just to look at..."Got 14 cylinders and use them all, overdrive tranny, she just won't stall......." A real "hot rod Lincoln! 4 carbs instead of 3.
Sounds pretty cool to me. Tubman, LZ; Lincoln Zepher ???
mfirth is offline   Reply With Quote
Old 04-23-2021, 06:44 AM   #17
tubman
tubman's Avatar
That's what I always thought.
Old 04-23-2021, 07:20 AM   #18
russcc
Whats that 14 cylinder weigh ?
Old 04-23-2021, 07:44 AM   #19
51 MERC-CT
51 MERC-CT's Avatar
Heard that it added 47 lbs. which required a special front spring package for the suspension.
Old 04-23-2021, 09:15 AM   #20
V8 Bob
V8 Bob's Avatar
I have never seen or heard of a V14 Ford or Lincoln engine, until now, and can find no history of one, so when were these made?
V8 Bob is offline   Reply With Quote
