04-22-2021, 04:46 AM | #1 |
Shift lever position / modification
The driving experience in my 38 is generally superb; however, the shift lever is just too close to my thigh in the first gear position - at 6’5” and 20 stone, not much I can do on my end. Any non-destructive / easily reversed work arounds out there ? Thank you,
No job’s done ‘til it’s all done |
04-22-2021, 06:03 AM | #2 |
Re: Shift lever position / modification
Not easily reversed, the shift lever has to be removed and heated red hot at the base and bent slightly. It's not a hard job but would have to replace the lever with another to get it back to original.
04-22-2021, 06:08 AM | #3 |
It might be possible to bend it cold if you could position it suitably in a press. I suspect heating and bending will be easier.
04-22-2021, 06:54 AM | #4 |
I measured how much I wanted to move mine. I put it in a vise and clamped a piece of angle iron to indicate where I wanted to bend it.
I heated and bent it. Turned out just right John
Welcome each day |
04-22-2021, 08:01 AM | #5 |
Red wrench it is ! Thank you all.
04-22-2021, 10:33 PM | #6 |
04-23-2021, 05:19 AM | #7 |
I would check the slot and pin fit on the ball section of the lever. A rebuild of that area may solve your problem. Just worth a look to see how worn it is. DO BE CAREFUL TO NOT DROP THE PIN IN THE SHIFT TOWER !! jm2cw. kerk
04-23-2021, 06:40 AM | #8 |
...and you know about not dropping the pin because...
