Old 04-01-2021, 10:40 AM   #1
Lefthander1930
Lefthander1930's Avatar
Default Fuel shut off valve
Fuel shut off valve, My Victoria has the fuel shut off valve in the engine compartment. It’s a pain in the butt to get in the engine compartment every time you wanna go somewhere while the fuel valve is shut off. Is there a cure or fix to get the fuel shut off valve working from the inside of the cab? Looking for some kind of device or a cure for this problem. Thank you
Lefthander1930 is offline   Reply With Quote
