Old 03-27-2021, 02:55 PM   #1
JD-OHIO
JD-OHIO's Avatar
Default Hub Cap Install
How to get a hub cap to not be loose when installing on a '31.
JD-OHIO is offline   Reply With Quote
Old 03-27-2021, 03:37 PM   #2
aermotor
Default Re: Hub Cap Install
Put clear silicone on the back side before installing wheel.
John
aermotor is offline   Reply With Quote
Old 03-27-2021, 06:48 PM   #3
McMimmcs
McMimmcs's Avatar
Only turn over every other ear and then lots of silicone.
McMimmcs is offline   Reply With Quote
Old 03-27-2021, 07:09 PM   #4
1946
1946's Avatar
To create an easy removal and less mess try a very thin "O" ring, ie. the rubber rings for sealing joints. I have even seen rubber band used as a stand by measure.
Tassie Devil
1946 is offline   Reply With Quote
