03-21-2021, 05:08 PM | #1 |
Need a new or rebuilt 1951 ford 6 cylinder water pump
Can anyone tell me where I can get a new or rebuilt 6 cylinder Water pump for a 1951 Ford Custom 6 cylinder engine?
Thank You! |
03-21-2021, 05:36 PM | #2 |
Re: Need a new or rebuilt 1951 ford 6 cylinder water pump
Is it the 226 I6?
19 and 49 F1 - jes' like Henry II built 1946 Deluxe - as Henry built it |
03-21-2021, 05:39 PM | #3 |
It is a straight 6 cylinder. I assume it is a 226.
03-21-2021, 05:42 PM | #4 |
Rare to find one. I bought a small rebuilt waterpump with the same size shaft (diaXlength) and put the new shaft,bearings and seal into my housing. Don't break your
pulley or impeller. Small press is handy. Skip may rebuild your Pump for you. Bruce
Works good Lasts long time |
03-21-2021, 06:18 PM | #5 |
The auction site and very expensive.
03-21-2021, 06:25 PM | #6 |
03-21-2021, 07:48 PM | #7 |
Thank You!!
03-21-2021, 09:43 PM | #8 |
The 226 water pumps are not reproduced and need to be rebuilt using your core. They are tricky to rebuild for the casual mechanic without a proper press. Best bet is to go to a known rebuilder. A number of members on FTE have used Cowboy John in Florida with good results. I've got a backup unit ready to head his way.
You'll want to be very careful with the thermostat housing as they are prone to cracking and are also not reproduced. https://cowboyjohnsautoparts.com/
03-21-2021, 10:03 PM | #9 |
I had a guy in Oregon rebuild a studebaker flathead six pump about two years ago. Of course I didn't save the receipt or info. He only rebuilds waterpumps. There was something in his business name about a 'Dutchman'
03-29-2021, 09:57 PM | #10 |
I sent it to Skip Haney in Florida for rebuild.
Thanks! |
03-30-2021, 07:58 AM | #11 |
I have a complete engine run a bowl sitting in the stand if you’re interested also J and I in Marshfield rebuilds Pumps
03-30-2021, 08:06 AM | #12 |
Complete engine 250 J&i 18004682439 4174682439 good people do starters and alternators and generators
04-07-2021, 02:31 PM | #13 |
Kanter Auto Parts lists them.
