Old 03-17-2021, 09:45 PM   #1
ford31
ford31's Avatar
Default tire question
about how much talcum do i put in each tire
ford31 is offline   Reply With Quote
Old 03-17-2021, 09:52 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: tire question
you can ask this in your original post.
McMimmcs is offline   Reply With Quote
Old 03-17-2021, 11:02 PM   #3
CWPASADENA
CWPASADENA's Avatar
Powder the inside of the tire casing real good so the tube will not get hung up or want to stick to a bare spot. I have purchased tubes when powder chalk was included. May be as much as a small handful. Powdered chalk does the same job as talcum powder.
My experience,
Chris W.
CWPASADENA is offline   Reply With Quote
Old 03-18-2021, 12:57 AM   #4
pbishop
Use talcum on 'both' the inner tube and on the inside of each tire. Do not leave any 'build-up or clogs' on either - just a smooth coating.
Remember, you also have to deal with the application of the tire to the rim - which sometimes requires a lubricant to facilitate mounting.
pbishop is offline   Reply With Quote
Old 03-18-2021, 10:48 AM   #5
ford31
ford31's Avatar
in our area cant find talcum,baby powder now is corn starch,is there another choice
Old 03-18-2021, 05:05 PM   #6
Jeff/Illinois
Jeff/Illinois's Avatar
Same here has to do with the big lawsuits against baby powder mfg.
Jeff/Illinois is offline   Reply With Quote
