Old 03-10-2021, 02:00 PM   #1
Greg Jones
Greg Jones's Avatar
Default Waxing a Canvas Top on Cabriolet 68B
I have a 68B Cabriolet with an old but still presentable top on it that has last all waterproofing characteristics (assuming it originally had any). It was suggested to me to use canvas wax which makes sense. But, before I go smear wax all over my top I thought I would check and see if any of you have done this with your Cabriolet or Roadsters? If so, can you recommend a product and any pitfalls to watch out for? Thanks
Greg Jones is offline   Reply With Quote
Old 03-10-2021, 02:32 PM   #2
ronn
Default Re: Waxing a Canvas Top on Cabriolet 68B
I asked the same question a few months back. The big thing to remember is not to use silicone based products.
you might want to try and find the thread....
Old 03-10-2021, 02:37 PM   #3
700rpm
700rpm's Avatar
I have some Canvex for my business coupe top, recommended by a model A friend, but I haven’t applied it yet. I’d like to hear if anyone else has used it. It has an odor, and I wouldn’t want that to permeate the inside of the cab.
Ray Horton, Portland, OR
Old 03-10-2021, 03:40 PM   #4
CabrioletDon
Hi, Greg! I don't know what "canvas wax" or other related products are, or what the the top on your 68B is made from...however, I used to own an auto upholstery business where we did hundreds of convertible top replacements each year. The only product we used and recommended to restore the repellant properties of a cloth top is 303 Fabric Guard. It's a product approved and recommended by Sunbrella and other commercial fabrics, and it always worked well for us. If you decide to use it, I'd try a little on a hidden spot first to make sure that there's no discoloration, and read and follow the directions exactly. It worked great on all sorts of tops, outdoor covers, boat canvas, etc. Hope this helps! --Don
CabrioletDon is offline   Reply With Quote
Old 03-10-2021, 03:47 PM   #5
sinbad339
sinbad339's Avatar
Based on the recommendation of a club member who owns a Sport Coupe (as I do), I bought this: https://www.amazon.com/Raggtopp-Fabr...xpY2s9dHJ1ZQ==
The cleaner part seemed to be somewhat effective, but I'm not sure that it was any better than the regular car wash detergent I use. The "Protectant" (waterproofing) does seem to help a lot. Previously, when driving in the rain for a while (maybe 30 minutes depending on how hard its raining), I could see that the canvas was wet on the inside. I haven't seen that since applying the product and driveing several times in pretty good rain. Note that with the bottle of protectant supplied, I was able to put on a good three coats.
"Our times are characterized by a perfection of means and a confusion of ends." - A. Einstein
sinbad339 is offline   Reply With Quote
Old 03-10-2021, 03:51 PM   #6
Ruth
I use 303 Fabric Guard on my Sunbrella car cover after it comes out of the wash to restore repellant. Works great for that. I have never used it on a top tho. Like Don suggests, "try a little on a hidden spot first to make sure that there's no discoloration, and read and follow the directions exactly."
Ruth
Old 03-11-2021, 07:09 AM   #7
Scott NY
Scott NY's Avatar
In the marine community most of us use the 303 on our boat canvas
Scott NY is offline   Reply With Quote
Old 03-11-2021, 07:05 PM   #8
700rpm
700rpm's Avatar
Does it have a lingering or invasive odor?
Old 03-11-2021, 09:22 PM   #9
Doug Linden
Doug Linden's Avatar
Another suggestion is to contact Haartz Upholstery Products in Acton, MA. They are still a major supplier for the material used on Cabriolet tops. I know they have products to clean and preserve that material.
Doug Linden is offline   Reply With Quote
Old 03-12-2021, 05:14 AM   #10
shew01
shew01's Avatar
I used 303 on Mazda Miata convertible tops years ago without issue. It has a slight smell in the bottle, but it doesn’t linger after application. It’s a great product.
shew01 is offline   Reply With Quote
