Old 03-05-2021, 04:23 PM   #1
flathead 53
Default pressed steel bellhousing ,clutch arm
The pressed steel bell housing used on some 51/53 flatheads , what is the correct installation of the clutch arm , you have the clutch arm , the spring that goes over it , then there is A metal plate that also goes on the arm and goes to the outside of the bell ,then there is a felt material that goes under the metal plate , is this correct .
flathead 53 is offline   Reply With Quote
Old 03-05-2021, 05:09 PM   #2
Bob C
Default Re: pressed steel bellhousing ,clutch arm
This is from Van Pelt's.
Old 03-06-2021, 10:12 AM   #3
V8 Bob
V8 Bob's Avatar
First, the stamped steel full bell was only used on '49-'51 Ford cars.
You are correct about the assembly: Clutch arm, anti-rattle spring 7562, plate 7513, and pad 7996. The '49-'51 shop manual shows the entire assembly.
V8 Bob is offline   Reply With Quote
Old 03-06-2021, 12:38 PM   #4
flathead 53
Thanks , question ,why is the pad used ? got one with the bell and was falling apart ,do I need the pad , going to use this bell on my 53 f-100 that I am installing A S-10 5 speed , I can fab and weld rear mounts to the steel bell ,that is why Im using that bell., with an adapter from offenhouser.
Old 03-06-2021, 01:39 PM   #5
V8 Bob
V8 Bob's Avatar
The spring 7997 slips over the end of the release lever and is sandwiched between the pad and release rod in the '49-'51 application. It looks like the spring simply keeps the plate in place to seal the bell.
Make sure you have the correct angled started plate that only works with the stamped bell.
