#1 |
Since LeBaron Bonney closed I am looking for a supplier of T-39 Stayfast Topping in neutral Beige, as well as 3/4" T-39DB Binding, and T-39H Hidem for my 32 Ford Roadster Top repair.
Would anyone have a source that you could recommend. Any leads would be very much appreciated. |
#2 |
Haartz (www.haartz.com) made all of LeBaron Bonney's Stayfast toppings and still do (make it for other customers).
#3 |
Try here: http://www.aro2000.com/
#4 |
Thank you David G and Merc Cruzer.
#5 |
As David mention, Haartz direct and when I was looking for green Haartz canvas for our 32 I called company called GAHH, there is also a good place in downtown LA that I have been to personally when I was out on the left coast and called when I was looking for green. maybe one of the LA crew here on the barn will chime in with the name???? I will also look through all my paperwork and see, I found a fellow in the upper mid west that was very very helpful when I called him, unfortunately he couldn't help me with the green (from what I already had) but he was very knowledgeable and helpful enough that we changed the color of the top!!! I'll do some more digging and see IF I can find his company and or name!!!
#6 |
Los Angeles, CA 90021 (800) 524 3330 |
#7 |
Might try Bill Hirsch in Newark, NJ 800 828 2061
#8 |
Thank you for all the leads.
Ford Barn is a great source of knowledge. |
#9 |
I have Mercedes Black on Black cloth on my roadster. What is the difference between that and Haartz Stayfast? I've also used the Mercedes cloth for a couple tonneau covers
#10 |
Perhaps none as Haartz is a Mercedes supplier.
#11 |
Maybe they just charge more because it says Mercedes?
#12 |
Highly likely!
