03-02-2021, 02:43 PM | #1 |
bore
I have a .0040 over bore on an 8ba I know this is basic but what is the bore in inches ? i am having a problem my pistons are very tight in the bore. I have to tap them to get them installed. I Really believe something is wrong.
03-02-2021, 02:51 PM | #2 |
Re: bore
I believe you mean .040 oversize.
Bore would be 3.2275 Plus clearance Last edited by KiWinUS; 03-02-2021 at 03:26 PM. |
03-02-2021, 02:58 PM | #3 |
Re: bore
Typical clearance is around .002 for cast pistons.
03-02-2021, 02:59 PM | #4 |
Re: bore
03-02-2021, 02:59 PM | #5 |
Re: bore
Standard bore should be 3.1875. Based on this you can calculate any oversize.
Not being snarky but .040 over should be 3.2275. C'mon Kiwi, get with the programme! Mart. |
03-02-2021, 03:14 PM | #6 |
Re: bore
03-02-2021, 03:17 PM | #7 |
Re: bore
no with the rings
03-02-2021, 03:26 PM | #8 |
Re: bore
Oh ya got me Mart. I even wrote it on my scratch paper correct but fat fingered & didn’t proofread.
03-02-2021, 03:29 PM | #9 |
Re: bore
Try using a micrometer on the pistons and cylinders to determine the actual clearances. Also, you need to check the ring end gaps for proper clearances.
03-02-2021, 04:16 PM | #10 |
Re: bore
thank you all I now have all my ducks in a row I am not a kiwi but i am an Ohio Buckeye that is a useless nut.
03-02-2021, 06:54 PM | #11 |
Re: bore
End gap couls be an Issue. Install a ring and measure it should be around .016".
Gramps |
03-02-2021, 07:52 PM | #12 |
Re: bore
If you are using a three piece oil ring they have a fair amount of drag when new.
03-02-2021, 08:02 PM | #13 |
Re: bore
Out of curiosity, are you using a ring compressor?
Wayno
Life is not a spectator sport. |
03-02-2021, 08:29 PM | #14 |
Re: bore
If you have checked for proper ring end gap the two compression and the one piece oil ring {I'm sure you did} then you may have a problem with the three piece oil ring. Its virtually impossible to check ring clearance on the three piece assembly. You can check the two steel oil rings from the assembly for gap but the expander cannot be checked. I have seen many times where the expander is actually to long. This will cause a very tight situation. I'm not saying that's what's happening however if you remove the three piece assembly and then try the piston again see what happens. Its worth a try.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-02-2021, 08:38 PM | #15 | |
Re: bore
03-02-2021, 09:38 PM | #16 |
Re: bore
I am using the three piece ring i have three types of ring compressers .
my favorite is a clamp type thanks to all of you you have no idea how much help you have been this is my last build I am having vision problems ,but with your help this one is becoming a special one . thank you again Chaplain Mike |
03-03-2021, 03:22 PM | #17 |
Re: bore
I did not see anyone mention bearing clearances......check all rods (and rod side clearances) and mains for proper clearances.......too tight will give you a motor hard to rotate.
