Old 03-02-2021, 02:17 PM   #1
Kajtek1
Kajtek1's Avatar
Default Sealing oil leaks?
Forum search did not find any hits, so am I first one trying to stop engine leaks?
From what I know my Ford wasn't started for several months and I could not start it for few days -waiting for new battery.
At the beginning I had constant drip from front seal. Not big, but in a week it made 4" spot.
Then I drove the car for couple of miles and when warm- I washed the engine with garden hose.
Now front seal stop dripping (love when things fix themselves) but I noticed smaller drip from rear seal and somewhere in starter area as well.
I know that back in 1922 the neoprene seals did not exist, so is there aftermarket supplier where I can buy upgraded seals?
Also my oil level is at max, so would lowering it 1/2" slow the leaks?
BTW my 2017 Ford F350 develop oil pan leak at 20k miles on Ford's flagship 6.7 diesel, so seems some things are unsolvable.
Kajtek1 is offline   Reply With Quote
Old 03-02-2021, 05:47 PM   #2
39portlander
39portlander's Avatar
Default Re: Sealing oil leaks?
Actually K seeing that it's March I knew this wasn't an April Fools pun T's weep, T's drip and there are some remedies and upgraded gaskets available.
I would suggest getting the 2 volumes of "Tinker'in tips" that have some good ideas to "slow down" the bleeding if you will.
Langs does have the newer seal material for the crank and upgraded seal for the cam.
Can't speak for your particular "modern" F350, my 2005 econoline puuurs like a kitten and does not leak a drop with 50+ currently. Might be an easy fix let us know how you make out.
39portlander is offline   Reply With Quote
Old 03-02-2021, 05:52 PM   #3
Kajtek1
Kajtek1's Avatar
Well... to some degree I expected that kind of reply, but I am die-hard DIY hobbyist and have more time to play than mechanic.
Some on this forum might be familiar with Detroit 2-cycle diesels as famous for leaving oil puddle.
I bought 1972 bus conversion with this engine when it was close to 40 yo and managed to make it bone dry.
What gave me the idea on T is fact that the rear was dry before and is wet now.
Front was wet before and is dry now. All it takes is figure out the dry part
Old 03-02-2021, 06:54 PM   #4
redmodelt
redmodelt's Avatar
"mtfca; oil leak" have fun reading!
Old 03-03-2021, 12:28 PM   #5
Kajtek1
Kajtek1's Avatar
Tried to register on mtfca, but they have those confirmation questions, that I can't answer right.
Was 3-speed and V6 available on Model T ?
WTH is thermo siphon?
Old 03-03-2021, 02:45 PM   #6
Kajtek1
Kajtek1's Avatar
Found about thermo siphon.
Nice video explaining things on 1922 model T.
Even I have the same year, we do have some differences.
My suspension also has coil springs. Is it something added later?
https://www.youtube.com/watch?v=R7xPzuYRC6g
Old 03-03-2021, 07:46 PM   #7
39portlander
Whoa......wait a minute here fella, you mean to tell us you have a model T and not sure if a V6 was available and not sure how natural convection works on the radiator and your initial concern is an oil leak. Come on Bro are you pull'in my leg.
Car guy advice... Buy the black Bible, aka. Model T service and the Model T Ford Owner by Murray Fahnestock aka The Dean of vintage Ford experts.
Read both publications COVER TO COVER and then get back to us, should shed some light on your dilemma
Old 03-03-2021, 09:00 PM   #8
redmodelt
redmodelt's Avatar
You don't have to sign up to read the forums. Just google what I posted and you will get lots of hits. Also get a copy of the Owners Manual. All the parts dealers will carry them. They were written for first time car owners and full of good information.
Old 03-03-2021, 11:17 PM   #9
Kajtek1
Kajtek1's Avatar
Why would I care if Model T could be available with V6 or 3- speeds?
I already learned that kerosene lamps were to avoid scarring horses when entering city streets.
When it is funny information, what is the use of it today?
Thanks for voting your opinion.
Right now I am numbered out from registering on other forum, so have to wait unspecified time for counter to reset.
Ford still waits for starter relay before I will work on it as I also have Sprinter project, so have to divide my time.
Old 03-04-2021, 12:56 AM   #10
redmodelt
redmodelt's Avatar
The question(s) is/are to weed people out that really don't have an interests in Model T's. The lamps were for when the car was parked or used for marker lights when the bulbs in the magneto powered bulbs burned out and had nothing to do with horses.
Old 03-04-2021, 01:19 AM   #11
JoeBauer
You don't need to join MTFCA to find answers there.
Google Search your question like this: "MTFCA oil leaks"
This is something that has been discussed many times on MTFCA, archived, and will show up in a search.
There are some really good people on MTFCA forum, and some real curmudgeons, but if you ask a basic question about oil leaks without doing a little homework first someone is likely to jump on you.
I recommend joining either Model T Ford Owners on Facebook or Model T Ford Club of Facebook, explain that you are a first time owner and ask away.
JoeBauer is offline   Reply With Quote
Old 03-04-2021, 07:26 AM   #12
39portlander
Gentlemen, seems to have turned out to be a "Cool hand Luke" moment. Hey...we tried.
Old 03-04-2021, 10:47 AM   #13
Kajtek1
Kajtek1's Avatar
I still can't get my answers on MTFCA right.
I put 3-speed
V6
clock
timer
as not available on T and it mark it wrong.
Old 03-04-2021, 11:13 AM   #14
redmodelt
redmodelt's Avatar
Yes there is a timer on a Model T. Yours may have an aftermarket distributor? The timer is what sends the signal to the coils to fire. Fits on the front end of the motor and is driven by the cam shaft. Again, "mtfca; timer" or even just "Model T Ford timer"
Old 03-04-2021, 11:20 AM   #15
Kajtek1
Kajtek1's Avatar
Thanks red, that worked.
Sounds like you need to be expert to register on other T forum .
Old 03-04-2021, 11:59 AM   #16
redmodelt
redmodelt's Avatar
Some of us spent time with our noses in books before we even had our first "Old Car". Than along the way had to re-learn a lot that hog -wash & wife's tails. You will get there.
Old 03-04-2021, 08:45 PM   #17
JoeBauer
The majority of the people on MTFCA are knowledgeable and friendly, but there are some cranky codgers who get tired of newbie questions. I identified myself as a newbie who knew nothing of T's and started asking questions, many ignorant, about getting a TT I bought going. They gave me so much hell I left.
I still get info I need by googling the site with my questions, but I don't need to belong or post.
I now have 2 TT's, a speedster, and a '26 Fordor. I drove my T's over 3000 miles last year. I don't need the MTFCA and their self-righteous crap to get answers.
I am still learning and T's are fun!
So just google your questions, or join a FaceBook Model T group.
Old 03-05-2021, 09:29 PM   #18
daren007
Starter relay?
daren007 is offline   Reply With Quote
Old 03-05-2021, 09:56 PM   #19
Kajtek1
Kajtek1's Avatar
Originally Posted by daren007 View Post
Starter relay?
Yes. I found 6V relay for 1/4 price the usual suppliers want for imitation of original switch.
From the look of burned switch it was newer installation who had some design flaw, so when the relay is already in, I am waiting for starter switch, who will be ignition -operated.
1 more safety feature.
Old 03-06-2021, 09:11 AM   #20
redmodelt
redmodelt's Avatar
Most that would bypass the starter switch would install; https://www.modeltford.com/item/A-STSOL-6.aspx with push button someplace within reach of the driver. Not sure what you are showing in above photo? Is your car 12 volts?
