Old 02-20-2021, 03:29 PM   #1
cluck
cluck's Avatar
Default two tooth steering box lubrication
Is it alright to use grease in the 1930 model-a steering box instead of 600wt oil?
cluck is offline   Reply With Quote
Old 02-20-2021, 03:44 PM   #2
Mister Moose
Mister Moose's Avatar
Default Re: two tooth steering box lubrication
Must ... resist....
OK, since you're new here, this has been extensively discussed recently:
https://www.fordbarn.com/forum/showthread.php?t=294412
Mister Moose is offline   Reply With Quote
Old 02-20-2021, 04:26 PM   #3
cluck
cluck's Avatar
Hello Mister Moose,
Thanks for your reply. Put the grease in about 4 years ago. So far the A still steers good , I have no leaks, and the lights all work good. I'm 86 so I think it will work ok for me.
Old 02-20-2021, 04:37 PM   #4
Curtis in MA
If you put it in 4 years ago why ask now?
Curtis in MA is offline   Reply With Quote
Old 02-20-2021, 04:58 PM   #5
Patrick L.
Patrick L.'s Avatar
Yep, its hard,,,
There is a lot of reading on this topic.
Old 02-20-2021, 05:11 PM   #6
Synchro909
Synchro909's Avatar
I think that if you were to add your heavy weight oil to the steering box now, it would mix with the grease and work just fine. IMO, grease is fine in there (but our steering boxes get hotter than yours because of the proximity of the hot exhaust but that is beside the point).
The problem with grease is that is MAY tunnel. The addition of some oil will thin out the grease enough to prevent that.
That said, I put a grease nipple between the bushes on the sector shaft and put some thick oil in through there for those bearings.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-21-2021, 08:43 AM   #7
nkaminar
nkaminar's Avatar
A modified end plate is available from the vendors to eliminate oil leaking into the light switch and onto the garage floor.
File Type: jpg Screen Shot 2021-02-21 at 8.41.01 AM.jpg (21.5 KB, 43 views)
Old 02-21-2021, 09:27 AM   #8
cluck
cluck's Avatar
good question.Just wanted other peoples opinion.
Cluck
Old 02-21-2021, 05:11 PM   #9
700rpm
700rpm's Avatar
The correct answer is NO.
Ray Horton, Portland, OR
Old 02-21-2021, 06:13 PM   #10
hudson32700
john Deere corn head grease.
hudson32700 is offline   Reply With Quote
Old 02-28-2021, 08:58 PM   #11
Model A Ron
Model A Ron's Avatar
I would never use grease.....it will not give the lubrication you need. Go with the oil.
Ron
Model A Ron is offline   Reply With Quote
Old 03-01-2021, 08:21 AM   #12
nkaminar
nkaminar's Avatar
The Ford service bulletins stress the point to NOT use grease in the steering boxes. Their point is that once the grease is forced out of the gear it is left dry and will rapidly wear and produce hard steering. The oil will continue to flow into the gear and sector to provide continued lubrication. The fitting that resembles a grease fitting was replaced by a plug in later production.
Old 03-01-2021, 09:00 AM   #13
Norm M
I just rebuilt a 2 tooth steering box for one of our club members. The car he bought had at least 8 inches of play in the steering. When I took it apart, it was FULL of grease but not on the worm gear and teeth of the sector shaft. The bearings look PK but both the worm gear and sector shaft teeth had extreme wear. I would not use grease.
Norm M is offline   Reply With Quote
Old 03-01-2021, 09:47 AM   #14
old31
Cluck do not use grease, it will be pushed away from were it needs to be. Use Corn head grease or tractor supply 00 grease.
Old 03-01-2021, 01:49 PM   #15
Flyboy1st
NEVER EVER use grease in the Model A steering box...except like our friends from down under who drive on the wrong side!
Flyboy1st is offline   Reply With Quote
Old 03-01-2021, 03:23 PM   #16
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube...................NO leakee.
Someone recently posted that Tractor Supply has something similar at less cost. FWIW
Paul in CT
Old 03-02-2021, 11:28 AM   #17
katy
katy's Avatar
What means PK?
Old 03-02-2021, 02:27 PM   #18
Norm M
Undershot the "O" while typing. It's supposed to be "OK"
Old 03-02-2021, 06:11 PM   #19
hudson32700
John Deere corn head grease is a semi fluid lubricant, not thick as most of us know grease.
Old 03-02-2021, 07:08 PM   #20
Mister Moose
I have Penrite, and there's a Tractor Suppply store near enough I can get some 00 grease.
If someone that has some JD Cornhead grease will mail me some, I'll perform some comparative tests. I'm thinking a pour test through an orifice the same diameter as the sector bushings would offer a good comparison.
Then we'll be down to just discussing motor oil and coolant.
