Old 02-11-2021, 05:38 PM   #1
hope
hope's Avatar
Default Volts?crab
What should be the voltage at the crab distributer, on a 12 volts system, with car running?
Hope.
hope is offline   Reply With Quote
Old 02-11-2021, 06:16 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Volts?crab
A lot depends on the coil you are going to use. A late 12-volt 3.0 ohm coil will work without a ballast resistor. A 1.5 ohm coil will need a 1.3 to 1.5 ohm ballast resister to function properly. An original coil can be rebuilt to work with 12-volts. Skip does them all the time.
When the car is running with the points opening and closing all the time, the voltage being indicated by a volt meter will not mean much.
Old 02-11-2021, 07:54 PM   #3
40cpe
40cpe's Avatar
Hope, I had essentially the same question. This thread has some good information in it, though it is a little long read.
https://www.fordbarn.com/forum/showthread.php?t=289706
40cpe is offline   Reply With Quote
