Old 02-02-2021, 07:18 AM   #1
Jakno
Jakno's Avatar
Default 59 Engine bolt torque
Have a 24 stud 59 Engine that I'm installing in my 35 pickup. Previous owner never heard it run but thought it had been rebuilt at some point. To check for condition we pulled the heads, intake and one rod and main bearing cap. Everything looked okay for my use plus engine is clean inside and out.
Has not had a total rebuild, only clutch, pressure plate and one set of valves.
I now realize that to re-assemble I should have torque spec's for main,rod,head and intake bolts. I started a search on this forum but it's too easy to get carried off onto other subjects. Would anyone have the spec's readily at hand and would share ?.
Thank You
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 02-02-2021, 07:27 AM   #2
chap52
chap52's Avatar
Default Re: 59 Engine bolt torque
Try Van Pelt Sales web site, www.VanPeltSales.com Walt has lots of spec info posted for these flatheads. A great place to do business with also. Chap
chap52 is offline   Reply With Quote
Old 02-02-2021, 12:35 PM   #3
34 GAZ
34 GAZ's Avatar
Is there a difference between 59 & 8BA torque specs.
34 GAZ is offline   Reply With Quote
Old 02-02-2021, 07:32 PM   #4
Mart
Mart's Avatar
This is what I've been using. Thanks to Mac Van Pelt.
http://www.vanpeltsales.com/FH_web/f...ecs32-48V8.htm
80-90 on the main caps.
35-40 on the con rods. (Castellated).
50-60 on cast iron heads.
23-28 on the intake manifold.
I show my technique for the rod nuts here:
https://youtu.be/n_WhWtBxH58
And the mains here:
https://youtu.be/xbMZwXWecMU
Mart.
Old 02-02-2021, 08:00 PM   #5
Will D
Will D's Avatar
Don't some 59's have full floating rod bearings that require different methods than just a torque spec? Can anyone clarify?
Will D is offline   Reply With Quote
Old 02-03-2021, 04:00 AM   #6
Mart
Mart's Avatar
No, Will, you just torque em up.
There is a procedure for ensuring the bearings fit with regards to roundness, but others like Ol Ron are more familiar with that than I am.
Mart.
Old 02-03-2021, 08:47 AM   #7
Will D
Will D's Avatar
Mart.
Thanks Mart. Some info sticks, some ends up fragmented... knew something was different about them but couldn't remember exactly what.
Old 02-03-2021, 09:22 AM   #8
macdonge
macdonge's Avatar
For inquiring minds regarding the correct fitting of full-floating rod bearings, check out this recent thread and the PDF I attached in post #64.
https://www.fordbarn.com/forum/showt...=255310&page=4
macdonge is offline   Reply With Quote
Old 02-03-2021, 10:01 AM   #9
Zeke3
Zeke3's Avatar
macdonge, that is an excellent document you put together on the art of fitting the full floating rod bearings. Thanks very much for the information.
Zeke3 is offline   Reply With Quote
Old 02-03-2021, 02:22 PM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
Ol' Ron also covered his procedure for fitting full floating rod bearings in his book, "Nostalgia", for those who may have a copy, or have access to a copy.
John
Old 02-03-2021, 05:21 PM   #11
oldford2
oldford2's Avatar
[QUOTE=Mart;1980937]This is what I've been using. Thanks to Mac Van Pelt.
I watched Mart's video on installing rod bearings. I always fit the crank bearing first. Tap , tap with a rubber mallet until if fits the crank. Not too snug and not too loose so it falls off. then can install the rods. I always have a piece of plastic tubing on each rod stud. One nick on the bearing can mean a long term problem. Also use assembly lube on all surfaces not oil. Plastic gage is your friend
JMHO
John
oldford2 is offline   Reply With Quote
Old 02-04-2021, 07:45 AM   #12
Jakno
Jakno's Avatar
Thanks to everyone for responding with your thoughts and information.
Excellent. It doesn't get any better than this
