Old 02-01-2021, 04:24 PM   #1
Tom in TN
Tom in TN's Avatar
Default Seeking Info on a 1939 Tudor Sedan
Hey y’all… a friend of mine has a 1939 Tudor Sedan that he is trying to title after it has been sitting in his family’s barn since the mid-60’s.
He’s wondering where the VIN is located on the car and does this number from the 1964 title sound like a normal VIN for the 39 tudor?: 4962832
Thanks for any help…
Tom in TN is offline   Reply With Quote
Old 02-01-2021, 04:34 PM   #2
mike in tucson
Default Re: Seeking Info on a 1939 Tudor Sedan
VIN sequencing did not start until 1968. Fords of the era had a serial number stamped on the drivers frame rail, most forward position is just forward of the firewall on the top side of the frame. The other two are not visible unless the body is removed from the car. The serial begins and ends with a "Star" stamp and can be a variable number of characters. See Mac VanPelt's web site for more info.
mike in tucson is offline   Reply With Quote
Old 02-01-2021, 04:36 PM   #3
40cpe
40cpe's Avatar
The VIN is stamped on the top of the frame rail on the driver side between the firewall and the front crossmember. It is usually located about where the steering gear is.
Van pelt lists the '39 serial numbers to be between 18-4,661,001 to 18-5,210,700
40cpe is offline   Reply With Quote
Old 02-01-2021, 04:38 PM   #4
VeryTangled
VeryTangled's Avatar
Hi Everyone, Tom, the vanpeltsales.com website has a very informative page that includes a list of serial numbers here:
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
That number does appear to be in the range for a 39 85hp transmission. ADDING: The number should begin and end with a star symbol, then begin with a 18- and followed with the serial. The 1939's ranged between 18-4661001 to 18-5210700.
Near the bottom of the VanPelt page is a diagram of a frame with the areas indicated where the serial number that was on the transmission was stamped on the frame as they were married.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 02-01-2021, 04:44 PM   #5
ford38v8
ford38v8's Avatar
Yes, and as stamped on the left front top of the frame: *18 4962832* The title may omit the prefix number 18 in some states, and never shows the stars as on the frame. The number is not a VIN, but rather, is the serial number of the engine/transmission assembly, stamped into the transmission bell before moving to the assembly line, where the number is then stamped into the frame. If the transmission has ever been replaced, the numbers won't match, but title goes with the frame anyway. Two other places to find the number, neither of which would have the prefix or stars: Midway top of left frame, hidden by the body, and top of left frame over rear axle. This last location is often not readable due to rust.
PS~ Jeff, you beat me to it! Heck, everyone beat me to it!
Alan
Old 02-01-2021, 04:57 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
This is the drawing (compliments of Mac VanPelt) that shows the relative location on a chassis to find the factory-stamped numbers. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-01-2021, 05:50 PM   #7
flathead 39
flathead 39's Avatar
YES, mine is 51##### on a Wisconsin title, located on left frame rail, easily seen by lifting the hood.
Much improved since Henry sold it.
flathead 39 is offline   Reply With Quote
Old 02-01-2021, 10:58 PM   #8
JayChicago
JayChicago's Avatar
On a car "sitting in a barn since the mid-sixties", you will probably need to do some cleaning of that section of the frame. And then maybe some de-greasing, too. The serial numbers can be difficult to read. They were just hand-stamped on the assembly line, are not stamped very deep. So use water and solvents to clean, but not abrasives.
JayChicago is offline   Reply With Quote
Old 02-02-2021, 05:24 AM   #9
Tom in TN
Tom in TN's Avatar
Thank you fellers, This is exactly the kind of information that Robby (my friend) was hoping I'd find.
Old 02-02-2021, 07:17 AM   #10
FortyNiner
FortyNiner's Avatar
As Jay indicated, avoid using abrasive materials on the stamped characters. Scotch Brite pads are the best choice.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 02-02-2021, 07:20 AM   #11
V8COOPMAN
V8COOPMAN's Avatar
Ya know, if by chance that '39 still has it's ORIGINAL transmission, the original Serial Number will be stamped into the flat pad at the very top, front of the transmission bell where it bolts to the engine block, similar to the number on this 1948 Ford transmission in picture. But be prepared for the number to be something altogether different though, as not TOO many of these old Fords still retain their virgin trans. DD
T5 W/TORQUE TUBE
Old 02-02-2021, 11:11 AM   #12
Tom in TN
Tom in TN's Avatar
I'll tell him coop. IIRC, this car was his grandad's from new, so the likelihood of the trans still being a virgin is greater than average. Thank you sir.
Old 02-03-2021, 07:24 AM   #13
Tom in TN
Tom in TN's Avatar
Here's a note from my friend - thanks for all the info!
"Tom, I was able to read the email earlier today but got sidetracked by an hydraulic issue. I was just able to read the email fully and I hopefully will be able to find the stamp tomorrow. Thanks for all your help! I didn’t know you would get that many responses that quick. Also there is a paper tag on the radiator from a service in the 40’s so I’m sure that the trans and other parts are original as the car only has 31k miles. Thanks again, Robby."
Old 02-03-2021, 08:19 AM   #14
Stretch Cab
Stretch Cab's Avatar
Tell your friend he owes some pictures of the car for all the help.
Let us live so that when we come to die, even the undertaker will be sorry. Mark Twain
Stretch Cab is offline   Reply With Quote
Old 02-03-2021, 01:55 PM   #15
flatford8
flatford8's Avatar
YA!... we gotta see / hear more about this car now!! .... ask him to join the Forum.... he’ll get all the knowledge of the entire group..... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 02-03-2021, 08:18 PM   #16
TJ
TJ's Avatar
Not only ask him to join this forum , but tell him to join the Early Ford V-8 Club of America(www.earlyfordv8.org) and have him buy the V-8 Club's 38-39 book. He will learn a lot about his car that he has become the caretaker of from grandpa. A very lucky guy.
Old 02-04-2021, 12:57 PM   #17
Tom in TN
Tom in TN's Avatar
I'll tell him guys!
Old 02-15-2021, 11:18 AM   #18
Tom in TN
Tom in TN's Avatar
For Stretch Cab and flatford8..as you requested...sorry, I don't know how to make 'em bigger...
Old 02-15-2021, 03:11 PM   #19
petehoovie
petehoovie's Avatar
Old 02-16-2021, 12:06 PM   #20
Sid the Maineiac
Sid the Maineiac's Avatar
What a great old Ford to start restoration on !Looks to be pretty much all there and not in bad shape !Tell your friend goodluck with it and make Grandpa proud !
Sid the Maineiac is offline   Reply With Quote
