Old 01-31-2021, 12:03 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default "Sharp Dressed "Crab " plate ......
I play music in the shop baesd on moods sometimes, this morning i played the ZZ Top sharp dressed man , kinda suits the mood i guess. I would call this a sharp dressed crab point plate :
1 media blasted point plate
2 painted with "never rust" black Trans Star primer
3 lube adjustment screw and turn with electric driver to aid machine testing
4 quality CS47 NAPA Echlin heavy duty contacts
5 contacts soaked with marvel mystery oil to retain lube
6 contact rubbing blocks with mobile one high temp grease
7 all screws replaced with stainless allen heads
8 contacts aligned (usually the right hand side needs bent )
9 brass washers using smaller cotter pins for a little bit more clearance .
There nothing like the smell of Marvel Mystery oil in the morning !!!!
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 01-31-2021, 12:11 PM   #2
Zeke3
Zeke3's Avatar
Default Re: "Sharp Dressed "Crab " plate ......
Bubba, that is a thing of beauty.
Zeke3 is offline   Reply With Quote
Old 01-31-2021, 01:07 PM   #3
Sid the Maineiac
Sid the Maineiac's Avatar
Yes,I agree,Zeke !It is indeed !
Sid the Maineiac is offline   Reply With Quote
Old 01-31-2021, 01:53 PM   #4
VeryTangled
VeryTangled's Avatar
Hi Everyone,
Jim/Bubba/Professor, Thank you sir. This is one very educational piece you've laid out!
Not many comments over they years about this, but you've got photo skills!
The red grease will not let you down. Many flatties out in the wild are still/again running thanks to your crew's magic touch and have that marvelous jelly hidden inside their vital bits.
Long live the hot sauce! This bottle was scored in Auburn IN! (My cr_p pics.)
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 01-31-2021, 03:04 PM   #5
petehoovie
petehoovie's Avatar
Old 01-31-2021, 04:20 PM   #6
mfirth
Jim, I'll bet you were wearing "white gloves" like the song says when you did that one. Love the cars in their videos. Wish i had a 59A with one of your "works of art" in it because
well, just because. Looks GR8 !
mfirth is offline   Reply With Quote
