#1 |
I'm looking for feedback as I've developed the setup in the photos.
I'm trying to get some idea of interest/demand. My estimation on selling price is $750-850. (The detail of the wheel lugs is not set in stone as the ones pictured are obsolete Dorman and I'm talking to ARP about something as an alternate, hence the price guesstimate) You'd receive what's in the 1st photo, less the hub, which I've shown only for illustration that you'd use your original drum hubs. Front disc brake kit, 1948-52 Ford F-1 pickup Features four-piston fixed calipers and 11” diameter 0.88” thick rotors. Retains the factory 5x5.5 bolt pattern and utilizes the original drum brake hubs. Wheelsmith 15” rims work fine and I suspect that the OE 15” rim will also work. Vehicle total front track width comes out at 1/4” less than factory specification. Steering wheel lock to lock turn specification is the same as factory. Calipers are a tried & true Kelsey Hayes design. Caliper attachment bolts, rotors and wheel studs are all OE application items. Last edited by 1948F-1Pickup; 01-28-2021 at 10:21 AM. |
