Old 01-26-2021, 05:54 PM   #1
sphooch
sphooch's Avatar
Question latest issue of restorer
Hi guys has any one read the latest issue of the restorer? I'm looking for help with the article about placing the stone guard inside the radiator shell. i started this task and mine looks different than the one in the article. i have a 31 roadster and no mention of removing the 4 rubber stand offs or the mounting tabs is mentioned. things are laying on the bench right now , i'm looking to see if anyone has done this on a 31 before i start cutting things up.any help in this is as always greatly appreciated. thamks THE HOOCH
sphooch is offline   Reply With Quote
Old 01-26-2021, 06:26 PM   #2
Bob C
Default Re: latest issue of restorer
Are you asking about these parts? I think you would just discard them.
Old 01-26-2021, 07:59 PM   #3
duke36
An alternative, so as not to destroy a good guard, would be to buy some 2.5 or 3.4 # diamond or similar mesh (plaster lath, etc), or perforated metal, paint black and apply to the core front or with wire or epoxy to the shell insides. If someone discards the post 2 parts, pm me.
duke36 is offline   Reply With Quote
Old 01-27-2021, 10:42 AM   #4
Bruce
Bruce's Avatar
Pitch the rubber standoffs and cut off the brackets. The screen will stay in place because you are gluing it inside the radiator surround. I successfully installed one in our 1931 Tudor. The surround and the screen are both slightly different than for a 1930. I recommend that you cut above the wire that intersects the bottom of the peep hole for a ‘31. I cut and glued, waited the cure time and then needed to trim another inch off the frame at the top for the perfect custom fit.
Bruce is offline   Reply With Quote
Old 01-27-2021, 11:04 AM   #5
duke36
Bruce: what type of glue did you use successfully to the shell ?
Old 01-27-2021, 12:03 PM   #6
Jordan
Jordan's Avatar
am I the only one who still hasn't received the restorer this month?
Cowtown A's
Jordan is offline   Reply With Quote
Old 01-27-2021, 12:16 PM   #7
Herb Concord Ca
I'm style waiting also.
Herb Concord Ca is offline   Reply With Quote
Old 01-27-2021, 12:17 PM   #8
Herb Concord Ca
Can't spell this morning. Should be still not style.
Old 01-27-2021, 12:37 PM   #9
McMimmcs
McMimmcs's Avatar
No you’re not. It’s a PITA !
McMimmcs is offline   Reply With Quote
Old 01-27-2021, 03:36 PM   #10
Bruce
Bruce's Avatar
J-B Weld 5020 PSI
Old 01-27-2021, 07:05 PM   #11
TerryO
TerryO's Avatar
My Restorer arrived in N GA today...
TOB
TerryO is offline   Reply With Quote
