Old 01-21-2021, 08:04 PM   #1
pjdeb
pjdeb's Avatar
Default Fact or Fiction: Headlight Lens Gasket
Fact or fiction: the neoprene gasket for the headlight lens has an adverse effect on the bucket finish? It tarnishes the aluminum surface?
pjdeb is offline   Reply With Quote
Old 01-21-2021, 09:09 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Fact or Fiction: Headlight Lens Gasket
Where is there any aluminum?
Old 01-21-2021, 09:36 PM   #3
Gary WA
Gary WA's Avatar
Should be cork tho!
www.whidbeymodelaclub.com
Gary WA is online now   Reply With Quote
Old 01-21-2021, 09:38 PM   #4
al's28/33
al's28/33's Avatar
Here Here!!!......cork.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 01-21-2021, 09:40 PM   #5
McMimmcs
McMimmcs's Avatar
Where did you hear that the bucket was made of aluminum ?
McMimmcs is offline   Reply With Quote
Old 01-21-2021, 10:42 PM   #6
160B
160B's Avatar
I think he is referring to the reflectors from the vendors that are aluminum.
https://www.brattons.com/newly-re-to...eflectors.html
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 01-21-2021, 11:11 PM   #7
McMimmcs
McMimmcs's Avatar
I am sure you are correct. Thanks for clarifying.
Old 01-22-2021, 01:42 AM   #8
MikeK
MikeK's Avatar
The original composite cork gaskets were bonded with vulcanized latex. Vulcanization is a cross-linking process that uses sulfur. Those gaskets would, upon gradual deterioration, out-gas sulfur dioxide. Sulfur dioxide reacts with silver to produce the classic silver tarnish that starts light yellow and progresses to black.
Back in the day coal was king in heating buildings and steam powering trains and industry. Because of the high sulfur content of most coal the atmosphere had quite a bit of sulfur dioxide that also contributed to silver tarnishing.
A lot of people mistakenly believe the yellow to black silver tarnish is oxidation. It is a sulfur reaction. Silver oxide is white and does not occur with atmospheric exposure at environmental temperatures.
Modern composite cork is bonded with a modified butyl compound and does not out-gas sulfur compounds. They have no affect on silver. Also, today's atmosphere is very low in sulfur compounds so silver reflectors need far less maintenance than they did in the Model A era.
A polychloropene ('Neoprene') gasket is relatively unreactive and does not out-gas any oxidant compounds. It will not directly react with silver or aluminum. Uncoated polished aluminum will react with oxygen in a damp atmosphere and oxidize to a grayish surface in a few months.
Brattons aluminized reflectors are overcoated with a silicate compound that isolates the metal surface from the atmosphere.
MikeK is offline   Reply With Quote
Old 01-22-2021, 08:51 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
False notion! My 45B Coupe has neoprene with aluminum reflectors since neoprenen became available. There is no evidence of tarnishing. My 190A Victoria has neoprene and aluminum since 2016 and there is no evidence of tarnishing.
Bob Bidonde
Old 01-22-2021, 09:43 AM   #10
pjdeb
pjdeb's Avatar
Thank you for the information. Yes, I was referring to the reflectors. Great explanation from MikeK.
Old 01-22-2021, 10:40 AM   #11
1crosscut
1crosscut's Avatar
I had my reflectors re-silvered 10 years ago. I just opened one up for the first time late this summer to replace a bulb. They looked like I just had them done.
Using cork gaskets.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-22-2021, 12:54 PM   #12
McMimmcs
McMimmcs's Avatar
Using cork gaskets.
Where did you have them resilvered ? Thanks Wayne
Old 01-22-2021, 07:51 PM   #13
1crosscut
1crosscut's Avatar
Wayne - [email protected] Craig Riker 419-290-4442 (Ohio)
Don't remember the price but it was rather reasonable and quick turn around.
Old 01-22-2021, 08:11 PM   #14
McMimmcs
McMimmcs's Avatar
Thank you for the information. I will attempt contact soon. I have 2 historic vehicles that replacement parts are not available for and they truly need resilvering. Thanks again, please be safe! Wayne
Old 01-22-2021, 09:18 PM   #15
700rpm
700rpm's Avatar
Very interesting. Do you have any information about atmosphere, pollution, and nickel plating? My replated for 15 year (2005) radiator shell is holding up much better than my original plated (1929) headlights did before 1950. Also my plating since 1980 seems to be holding up pretty well too.
Ray Horton, Portland, OR
Old 01-23-2021, 08:16 AM   #16
MrBruce
MrBruce's Avatar
My 31 S/W Town Sedan had silvered reflectors when I bought it 38 years ago, every car coming towards me at night flashes their lights at me. They are as bright now as they were when I bought the car. No tarnish so far, and I would pay the extra to have them done if and when I buy another model A.
MrBruce is offline   Reply With Quote
Old 01-23-2021, 12:16 PM   #17
Ruth
Just a thought, are people flashing their lights at you because your lights are bright? Or because they are out of adjustment? I have seen more than one Model A with headlights pointed in the wrong direction.
Ruth
Old 01-23-2021, 12:30 PM   #18
MrBruce
MrBruce's Avatar
My lights are adjusted perfect
Old 04-13-2023, 11:32 AM   #19
Kentmac
Would a bead of silicone work ?
Kentmac is offline   Reply With Quote
Old 04-13-2023, 11:38 AM   #20
J Franklin
J Franklin's Avatar
It is not needed or wanted. Use a correct gasket from one of the vendors.
