Old 01-21-2021, 08:52 AM   #1
cowtown
Default Gas Tank Sealer
I need to seal the gas tank on my 29 pickup. What product have You used that worked well?
cowtown is offline   Reply With Quote
Old 01-21-2021, 09:30 AM   #2
Chris in WNC
Chris in WNC's Avatar
Default Re: Gas Tank Sealer
none. just find a clean tank and swap it.
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 01-21-2021, 09:39 AM   #3
cowtown
Thanks Chris, Very helpful
Old 01-21-2021, 09:40 AM   #4
cowtown
i would have never thought of that
Old 01-21-2021, 09:49 AM   #5
Chris in WNC
or find a shop that can open it up, sandblast it and weld back together like Brent Terry has done....
Old 01-21-2021, 10:47 AM   #6
ronn
only Hirsch located in Newark NJ
they use it in airplanes.........so think of the failure rate.
Old 01-21-2021, 12:09 PM   #7
WHN
Don’t be concerned about using a good sealer. Follow the direction completely. The tank on a 29 is not hard to remove.
We did ours 30 plus years ago and it solved all our problems.
Back than, we purchased the sealer from Mac’s.
Just use a really good quality sealer and follow the instructions to the tee.
Good luck.
WHN is offline   Reply With Quote
Old 01-21-2021, 01:34 PM   #8
JayJay
As good as any is the POR-15 system. Motorcycle folks have been using it for years. Biggest thing, whichever system you use, is to make sure that it specifically mentions being resistant to high-alcohol fuels as sometimes you may not have the option of using non-alcohol fuel.
And follow the prep directions to the letter.
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 01-21-2021, 03:36 PM   #9
Synchro909
Synchro909's Avatar
I have 4 Model As and every one of them has had the tank sealed. I drive several thousand miles a year and have never had an issue with it. I did have trouble once with a tank I hadn't yet gotten around to sealing shed very fine rust "dust" as fine as talc. It plugged up the filter. Now that I have cleaned out the tank and sealed it, I have no second thoughts about setting out on a trip of several hundred miles
If you use a good quality sealer and follow the instructions, you will be better than good.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 01-21-2021, 04:09 PM   #10
nkaminar
nkaminar's Avatar
Not on a Model A but on a boat, I have used the sealers that are used to seal aircraft tanks. I bought the sealant from https://www.aircraftspruce.com/. It can be thinned with MEK. Tank has to be clean.
Warning: This stuff is hazardous to your health. Use PPE.
Old 01-22-2021, 02:25 PM   #11
AL in NY
AL in NY's Avatar
I second what JayJay said. I did my tank 15 years ago and have had NO problems since. I used the 3 step POR-15 sealer. Again, follow the prep steps to the letter.
AL in NY
AL in NY is offline   Reply With Quote
Old 01-24-2021, 04:39 PM   #12
Fred K OR
Get a good sealer from one of the good vendors. It works, done it in both of my A's and have had no problem.
Fred K OR is offline   Reply With Quote
Old 01-25-2021, 04:23 AM   #13
ronn
Many guys are against the sealers. I have used both good and bad.
a good sealer will last most of our lifetimes.
Old 01-25-2021, 08:07 AM   #14
Oldbluoval
Oldbluoval's Avatar
Fred
How about sharing who and what?
Your reply is rather vague!
Oldbluoval is offline   Reply With Quote
Old 01-25-2021, 08:58 AM   #15
ronn
keep saying it Hirsch is the best- if they use it in airplanes, do you think it will fail?
Old 01-26-2021, 09:41 AM   #16
Benson
Does the FAA allow ethanol in aviation gasoline?
Ethanol might be the cause of sealer failure.
The last time I heard ethanol is NOT allowed in aviation gasoline.
I wonder if Aviation gas has all of the Guberment (sic) mandated chemical makeup and junk that standard pump gas has..
That might be why there seems to be no problems with tank sealers in airplanes!
Just saying ...
Benson is offline   Reply With Quote
Old 01-26-2021, 08:10 PM   #17
Oldbluoval
Oldbluoval's Avatar
No ethanol in avgas per my buddy who’s had a plane and flown for 55 years
Old 01-27-2021, 09:35 PM   #18
mass A man
mass A man's Avatar
30+ years ago I sealed a '27 Packard tank with the Bill Hirsch sealer, tested against the "new" alcohol being put in the gasoline. It was a thinner, whitish sealer compared to the older, non-alcohol type which he sold, it was a thicker, honey colored sealer. As far as I know, the Packard is still going well since I sold it. Have no rust in the Model A tank.
mass A man is offline   Reply With Quote
