Old 12-23-2020, 09:40 PM   #1
Cadillac Bill
Cadillac Bill's Avatar
Default My Friend BB wants pros and cons to upgrade to 12volt system
My friend BB has a 53 Mercury and thinking about upgrading to a 12v system.
Pros and Cons?
Your opinion?
Cadillac Bill is offline   Reply With Quote
Old 12-23-2020, 09:48 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: My Friend BB wants pros and cons to upgrade to 12volt system
Tell your friend to google the keywords pros and cons to upgrade from 6 volt to 12volt system
8^) Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 12-23-2020, 09:51 PM   #3
Joe Immler
I have had my restored 1941 Coupe for 30 years. It is 6 volt. I have had no reason to convert to 12 volt. I changed my tail lights to LED as they were very dim. Fabulous now.
I put my battery on a trickle charger when I put the car away for winter. I bought the battery new in 2013 and it is still just fine. If one cares for and maintains a 6 volt system
all seems well. The only reason I can see going to 12 volt would be to upgrade to a good radio or something.
Joe Immler is offline   Reply With Quote
Old 12-23-2020, 10:07 PM   #4
whizzernick
whizzernick's Avatar
very easy to change to 12 v (I use original generator with cut out--My car is a 1933 ) generator charges 12v battery just fine I drove my 1933 roadster to grand national meet in 1983 (and many other meets ) YOUR 41 you might have to get a 12 volt gen and regulator . ( I think a late ford gen and regulator will work ( other barners would know )
I use original coil ( I just add a resistor to original resistor) I use 65 mustang resistor (must keep it FORD )
change all light bulbs
easy to change back --- + or - ground --- I keep battery tenders on most of the time.
The good (brighter lights ) easy to get a new battery---- easy to change back if you want--- easy on older wireing ( 12 volts is 1/2 the amps ) cell phone charger --- modern radio ( you can hid it )
whizzernick is offline   Reply With Quote
Old 12-23-2020, 10:47 PM   #5
skidmarks
skidmarks's Avatar
The only con, and ive had it happen a couple times. If you keep the 6v starter, putting 12v to it can break the bendix spring.
A big plus is 12v batteries are easy to get and tend to last longer and easier to jump start.
skidmarks is offline   Reply With Quote
Old 12-24-2020, 12:16 PM   #6
johndee138
johndee138's Avatar
Not to mention the aftermarket backup cameras, cigar lighter driven accessories, like a fan for the driver, phone charger, etc, etc.
I LOVE the cigar lighter driven rear view camera for my car, it is priceless and only cost $40 on amazon.
I also rigged up a 12v boat bilge pump fan to an intercooler submerged in an ice chest for the hot summer days. Poor mans air conditioning!
I did swap my starter for a 12v one, the 6v hit so hard on 12v that I was afraid it would break in the most inopportune time, like when the wife and I were off somewhere inconvenient
johndee138 is offline   Reply With Quote
Old 12-24-2020, 12:56 PM   #7
McMimmcs
McMimmcs's Avatar
8^) Jack E/NJ
I agree and it will keep him busy a while !
McMimmcs is offline   Reply With Quote
Old 12-24-2020, 01:51 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
And what accounts for all the bendix springs that have broken while the starter was being powered with 6 volts?
Old 12-24-2020, 02:08 PM   #9
36fordguy
easier to change to LED bulbs Better lighting and less power 36fordguy
36fordguy is offline   Reply With Quote
Old 12-24-2020, 03:03 PM   #10
skidmarks
skidmarks's Avatar
Age
Old 12-24-2020, 04:38 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
51 MERC-CT>>>what accounts for all the bendix springs that have broken while the starter was being powered with 6 volts?>>>
skidmarks>>>Age>>>
My starter spent the first 21 years of its life cranking its 21-studder on 6v. Then another 3 years on 12v. Then it rested 48 years; it was incompatible with a SBC. For the last 10 years it's been cranking its 21-studder again on 12v. So if my calculations are correct, proof-positive that its bendix has lasted 8 years longer on 6v than 12v so far. 8^) Jack E/NJ
Old 12-24-2020, 04:39 PM   #12
Strick
Strick's Avatar
sent you a PM about your friend's 53 Mercury
1940 Mercury Coupe
1940 Ford Standard Business Coupe
Looking for Kurten - Spalding - Harman Collins - W&H Ducoil - Berk - Kong - Eddie Meyer dual coil converted dizzys
Strick is offline   Reply With Quote
Old 12-24-2020, 11:50 PM   #13
JM 35 Sedan
JM 35 Sedan's Avatar
Murphy's general laws
• Nothing is as easy as it looks.
• Everything takes longer than you think.
• Anything that can go wrong will go wrong.
• If there is a possibility of several things going wrong, the one that will cause the most damage will be the one to go wrong. Corollary: If there is a worse time for something to go wrong, it will happen then.
• If anything simply cannot go wrong, it will anyway.
• If you perceive that there are four possible ways in which a procedure can go wrong, and circumvent these, then a fifth way, unprepared for, will promptly develop.
• Left to themselves, things tend to go from bad to worse.
• If everything seems to be going well, you have obviously overlooked something.
• Nature always sides with the hidden flaw.
• Mother nature is a bitch.
• It is impossible to make anything foolproof because fools are so ingenious.
• Whenever you set out to do something, something else must be done first.
• The Light at the end of the tunnel is only the light of an oncoming train.
John
Old 12-26-2020, 11:37 AM   #14
Zeke3
Zeke3's Avatar
And, by many reports, Murphy was an optimist.
Zeke3 is offline   Reply With Quote
Old 12-27-2020, 01:25 PM   #15
Epper1
Epper1's Avatar
Had no problems with 6 volt starters changed to 12 volts
Epper1 is offline   Reply With Quote
Old 12-27-2020, 01:41 PM   #16
McMimmcs
McMimmcs's Avatar
I changed 2 since June and both bendix springs broke.
Old 12-27-2020, 02:48 PM   #17
VeryTangled
VeryTangled's Avatar
Hi Everyone. One consideration would be who is gonna help you when you have to do troubleshooting? The farther a vehicle is from stock the more variables are inserted, I feel.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
Old 12-27-2020, 04:55 PM   #18
Robz51
Robz51's Avatar
My 52 merc has been 12 volts for 26 years. The engine has been 12 volts for 32 years and I've never laid a hand on the starter. Just my experience. Make sure you yse the correct resistors(regulator) for the gauges. I know there are merits to 6 volts and they can be reliable. Guess it's a personal choice.
Sent from my SM-G955U1 using Tapatalk
Robz51 is offline   Reply With Quote
Old 12-27-2020, 06:36 PM   #19
estout81
No difference in troubleshooting. Just different numbers on the meter.
estout81 is offline   Reply With Quote
Old 12-27-2020, 09:10 PM   #20
JSeery
JSeery's Avatar
And to non-early Ford people the positive ground can be a challenge.
