12-17-2020, 03:35 PM | #1 |
Where do I drill the holes to mount cowl light on a 32?
I want to put cowl lights in the proper place on a 1932 Ford. Can someone give me the exact details or where to find a template?
Matt 24:36-41 |
12-17-2020, 04:04 PM | #2 |
Re: Where do I drill the holes to mount cowl light on a 32?
Use a hole punch for clean edges.
12-17-2020, 04:18 PM | #3 |
I am looking for info on the exact spot to put the holes where Henry had them.
Matt 24:36-41 |
12-17-2020, 04:20 PM | #4 |
Should be able to extrapolate from these!!!
12-17-2020, 04:20 PM | #5 |
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell |
12-17-2020, 04:28 PM | #6 | |
12-17-2020, 05:05 PM | #7 |
Look on the underside of the cowl. There may be a re-inforcing plate there.
12-17-2020, 05:08 PM | #8 |
There is, so I guess thats where it goes.
Matt 24:36-41 |
12-17-2020, 05:43 PM | #9 |
I am very sorry that my 32 Ford Cowl is inaccessible, so I can't get accurate measurements. I hope that this photo helps is of some help. I am sorry that I can't do any better. Last edited by mercman from oz; 12-17-2020 at 09:47 PM. Reason: Picture got deleted |
12-17-2020, 06:05 PM | #10 |
All but some very early '32 passenger car bodies have those reinforcing plates with the requisite holes included whether or not the body was destined to be equipped with cowl lights further down the assembly line.
12-17-2020, 06:14 PM | #11 |
I don't know if the size is the same as the hole in the reinforcing plate on Model A's but Bratton's sells a Cowl Light Installation Tool. It's a dowel that fits in the hole with a hardened pin in the center. Insert the dowel and tap the pin and it locates the exact center of the plate. PN 18430 at $3.00.
12-17-2020, 06:48 PM | #12 |
Thanks to everyone..☺
Matt 24:36-41 |
12-17-2020, 08:11 PM | #13 |
12-17-2020, 08:21 PM | #14 |
12-17-2020, 09:45 PM | #15 |
For some reason, the picture that I attached to my earlier Post went missing? This is the best that I could do, as the cowl is in a very inaccessible location. |
12-19-2020, 01:12 PM | #16 |
Cancel post
12-19-2020, 09:35 PM | #17 |
I think they look good here.
