Old 12-12-2020, 04:23 PM   #1
Ronnieroadster
Ronnieroadster's Avatar
Default 1932 V-8 original steel cam
I'm in the process of building a flathead V-8 which will have an original Ardun overhead valve conversion on it. The preferred cam for the way I'm building this particular engine is the Ford V-8 steel cam used in 1932 and I believe also during the 1933 production. If anyone has a used cam they would be interested in selling please let me know by sending me a personal message.
Ronnieroadster.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
