12-04-2020, 11:24 AM | #1 |
Torque wrenches
What is recommended as a good torque wrench for flathead stud nuts. The Craftsman split beam I used for years may not be that accurate. All I use it for is head stud nuts. If I were to get a new one with a range of 20-60 or 75 ft lbs, any suggestions. I torque the flatmotor up 55# and that's it.
12-04-2020, 11:27 AM | #2 |
Re: Torque wrenches
I bought a Precision Instruments PREC3FR250F 1/2 Inch Torque Wrench. Very happy with it. Made in the USA and comes with a case.
BTW: Precision Instruments makes Snap-On's torque wrenches. My buddy, who is a Snap-On dealer, suggested I get the Precision Instrument unit since it's the same one he sells on his truck, just with a different label, different colored handle and a lot cheaper. Last edited by Tim Ayers; 12-04-2020 at 12:17 PM. |
12-04-2020, 12:03 PM | #3 |
Re: Torque wrenches
I stepped up on a Snap-On.
12-04-2020, 12:10 PM | #4 |
Re: Torque wrenches
I found the torque wrenches at Lowes and Home Depot to be good.
12-04-2020, 12:15 PM | #5 |
Re: Torque wrenches
Thank you. I will check out the suggestions.
12-04-2020, 03:15 PM | #6 |
Re: Torque wrenches
12-04-2020, 03:26 PM | #7 |
Re: Torque wrenches
Believe it or not, Harbor Freight has started to offer higher quality tools lately... including torque wrenches. Here are some tests of them against big names... as well as checking against calibration machines.
Harbor Freight Icon ($109) vs. Snap-On ($400) Here is a spoiler, when it comes to accuracy, the Icon actually won. https://www.youtube.com/watch?v=ck_O5U1Tyz8 Harbor Freight Quinn electronic. $169 and really nice if you like torque wrenches with batteries. Uses two AA batteries that can be removed for storage... which is recommended. Also does torque angle. Super accurate... and many like it better than the Snap On. https://www.youtube.com/watch?v=ck_O5U1Tyz8 https://www.youtube.com/watch?v=ck_O5U1Tyz8 Some may not know about 'Torque Angle'. This is where the tightening specific tells you to torque to a lower number such as 40 ft-lb... then to turn it a number of degrees past that. An example would be 40 ft-lb plus 90 degrees... or 70 ft-lb plus 45 degrees. You can set the electronic wrenches for the spec, and they will tell you when you have rotated the fastener that exact amount. YES. They even measure degrees. For the style wrenches seen in the Icon vs. Snap-On video, do not store the wrenches with the torque cranked up. Always dial them back to zero for storage to best maintain calibration.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. Last edited by FL&WVMIKE; 12-04-2020 at 03:32 PM. |
12-04-2020, 03:32 PM | #8 |
Re: Torque wrenches
I tested several harbor freight ones, the cheapest ones and they were all very close
12-04-2020, 03:33 PM | #9 | |
Re: Torque wrenches
It could be me and my bias, but I just don't trust critical measurements or specs to a lower quality tool such as what Harbor Freight sells. I may be in the minority and the fool for spending more, but I'm happy to own and support tool makers who are still making tools in the USA. If I recall, the PI torque wrench I bought was $169.00 shipped and made in the USA Last edited by Tim Ayers; 12-04-2020 at 03:44 PM. |
12-04-2020, 03:38 PM | #10 |
Re: Torque wrenches
Next thing you know, we'll be putting a man on the Moon! YWB
12-04-2020, 03:41 PM | #11 |
Re: Torque wrenches
No more Snap on torque wrenches for me. The ratchet head is bad on mine and the head is no longer made so I am out of luck. They will sell me a new complete one. Yea I bet they would. So much for the lifetime warranty, and I do understand the torque wrench side is not warrantied for life but I feel the head should have been. Thanks
12-04-2020, 03:44 PM | #12 |
Re: Torque wrenches
Confidently using my monkey wards beam wrench I bought 45 years ago.
12-04-2020, 03:53 PM | #13 |
Re: Torque wrenches
Pete has it right on the old deflecting beam types. They were inexpensive and lasted a lifetime for guys that just use them now and then. I'm not sure whether many are made anymore but I'm sure they still are.
I've used Snap On for over 40-years and don't have much problem with them. I get them checked every year and they always pass. The best ones were the old dial beam type but I don't think they make them any more. On the ratchet types, a person may be able to find an old Snap On ratchet that would provide replacement parts but I don't know what part broke for Steve O. I rarely have any problems with them but I don't use them as much as my regular ratchets. Most of mine have the high strength replacement gears in them for the older units I have. The later ones all have the heavy duty gears. I'm just glad I bought mine back when they were a lot less expensive. You have to pay top dollar for the US made stuff now. |
12-04-2020, 04:25 PM | #14 |
Re: Torque wrenches
Actually just talked myself into the Quinn digital... as I do some torque angle stuff. From what I read, the company that makes them does the electronics for MAC, etc. I used a coupon code... 23865527 that dropped the price WITH tax and shipping down to $142.55! Coupon code was worth $42.50!
As was said, do not store the tool with the batteries installed in case they decide to leak or corrode. Luckily, it comes with two simple AA batteries. Nothing fancy.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. Last edited by FL&WVMIKE; 12-04-2020 at 06:14 PM. |
12-04-2020, 04:25 PM | #15 |
Re: Torque wrenches
Delete... Double post
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. Last edited by FL&WVMIKE; 12-04-2020 at 06:13 PM. |
12-04-2020, 06:47 PM | #16 | |
Re: Torque wrenches
As for the torque angle... You can even ratchet the wrench while doing the angle, and it will still work. https://www.youtube.com/watch?v=-_biYSzH87o&t=350s https://www.youtube.com/watch?v=r7GaR5mh10k
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
12-04-2020, 07:09 PM | #17 |
Re: Torque wrenches
Hi rotorwrench, Some years ago the rachet head started slipping. At that time Snap-on did put a kit in it and I had it calibrated. Only used one time for a small job not high ft lbs. Next time probably a year later I went to torque hub nut on my focus 165 lbs it slipped again. This time its the head thats worn out (was the first time too) but not available so they wont do anything about it (5 different snap-on dealers). I've watched for a ratchet to get the head but at this point I think I'm just going to weld it and use a ratchet adaptor where I cannot use it locked.
12-04-2020, 08:00 PM | #18 |
Re: Torque wrenches
torque wrench's are never 100% the trick is that there consistent 55ftlbs 54ftbs or 56ftlbs doesn't really matter its that they are all the same every time . there are good tradies out there that will reset your wrench if its out and the cost is minimal We have 10 different wrenches from 1/4" to 1,1/2" drive in the w/shop and get them done every 12 months the cost is minimal
12-04-2020, 10:13 PM | #19 |
Re: Torque wrenches
That old beam type wrench is likely to be the most accurate and repeatable choice. I build diesel engines every day for a living and use modern torque wrenches because they're quicker,have audible alerts, and have ratchet heads....but when I build an engine for my cars I use the old reliable Craftsman bending beam wrench. In the decades I've owned it the calibration has never changed.
Terry
12-05-2020, 07:58 AM | #20 |
Re: Torque wrenches
I have a couple Craftsman bean types - work very well. I also have a really nice MAC long 'clicker' type (ratchet head, etc). It is really nice to use on higher torque applications - like the rear axle nuts on a banjo rear . . . try doing that with one of my Craftsman beam ones . . .
