Old 11-29-2020, 05:49 PM   #1
eddie48
Default 34 pickup oil pressure guage
I want to install an oil pressure guage. Where on the engine is a good place to attach it? I see some fittings that look right on the left (driver side) rear of the block just below and to the rear of the head. Is that oil?
Thanks,
eddie48 is offline   Reply With Quote
Old 11-29-2020, 10:15 PM   #2
JSeery
JSeery's Avatar
Default Re: 34 pickup oil pressure guage
Think you ended up posting the same question twice, but yes, that is the correct place to connect an oil pressure gauge line. There are two outlets, one vertical and one horizonal. They both go to the same oil port.
Old 11-30-2020, 06:38 AM   #3
eddie48
Thank you. Yes I did post it twice. When I saw it I tried to remove one but could not figure out how to do it.
Thanks, again.
Ed
