Old 11-22-2020, 05:29 PM   #1
Conaway2
Conaway2's Avatar
Default Horn Rod Disassembly
I’ve removed the rod from the steering column, have bent the 4 tabs under the button up straight, but the retainer around the horn button will not budge. Does anyone have any suggestions on how to remove it without damaging anything ?
Thanks - Jim
Conaway2 is offline   Reply With Quote
Old 11-22-2020, 05:39 PM   #2
jw hash
jw hash's Avatar
Default Re: Horn Rod Disassembly
i bore a hole in a piece of wood just a little bigger then the ring stand the rod up so the ring is in the hole and use a small hammer and tap it out.
jw hash is offline   Reply With Quote
