Old 11-13-2020, 03:15 PM   #1
m.eaton
Default v8 60
hi, just committed to getting a v8 60 from a friend of a friend situation. the current owners till me there is a number on the bellhousing that reads j8E.
there are probably other numbers and ways to identify this motor. without having the motor yet or knowing what to look for how do i tell the differences between them?
m.eaton is offline   Reply With Quote
Old 11-13-2020, 03:27 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: v8 60
Don’t believe numbers mean much. 3 main differences. Tin sides are early 37 only. 1940 have larger rod & main journals with longer snout crankshaft. In between are all the same.
Cheers
Tony
Old 11-13-2020, 03:40 PM   #3
JSeery
JSeery's Avatar
Default Re: v8 60
There is some information on VanPelts site: http://www.vanpeltsales.com/FH_web/f...cs-V8-60hp.htm
Old 03-24-2024, 02:11 PM   #4
Brillman
Brillman's Avatar
Default Re: v8 60
Cheers
Tony
Hey im looking for some v8 60 parts, i seen a post u said that you have some. Im in Va
Brillman is offline   Reply With Quote
Old 03-24-2024, 02:26 PM   #5
KiWinUS
KiWinUS's Avatar
Default Re: v8 60
What are you needing?
Old 03-25-2024, 10:21 AM   #6
matterick
Default Re: v8 60
Post what you need in the classified. Somebody here will have the stuff
matterick is offline   Reply With Quote
Old 03-25-2024, 10:25 AM   #7
Seth Swoboda
Seth Swoboda's Avatar
Default Re: v8 60
I have been advertising V8 60 parts for sale on the swap meet page. I sold some. I have a timing gear and crank gear, tansmission cluster gear, some valves, guides and springs left. All NOS parts.
Seth Swoboda is offline   Reply With Quote
