Old 11-13-2020, 12:48 PM   #1
cvicky
cvicky's Avatar
Default oil bath conversion
i want to cut inside of breather and put paper filter
55 fairlane 272
anyone know which fram air filter fits
cvicky is offline   Reply With Quote
Old 11-13-2020, 01:09 PM   #2
miker98038
miker98038's Avatar
Default Re: oil bath conversion
This might help.
http://forums.y-blocksforever.com/Topic131104.aspx
Bottom of his post Ted lists the filter part numbers. I don't know how close this is to your a/c, but Ted says it's a 55 teapot.
miker98038 is offline   Reply With Quote
Old 11-13-2020, 04:55 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
IMO, the oil-bath air cleaner is superior to a paper filter. Oil-bath system is less restrictive on air intake and will still allow air through even when there's lots of dirt in the oil. The paper filter will clog and restrict air flow even more as dirt enters the filter.
Only drawback to the oil-bath type is occasional cleaning and re-oiling can be messy unless you are set up for it. I used to know some folks who would keep a second identical oil-bath air-cleaner cleaned, covered in cellophane and ready to install while using the other one and swapping when the used one got dirty, so they could set the used one aside until they found a convenient time to clean it and store it for swapping back after the other one got dirty.
If the cleaning process involves wiping the exterior of the air-cleaner with solvent (gas or whatever), resulting in destroying the paint finish, then somebody has painted the wrong paint on it. Refinish it with the original FOMOCO Argent silver enamel and you will not have that problem again.
Daves55Sedan is offline   Reply With Quote
Old 11-13-2020, 08:40 PM   #4
scicala
scicala's Avatar
Whether you're talking about a two barrel or a four barrel air cleaner makes a big difference too. Both carbs were available on '55 272's.
Sal
Old 11-13-2020, 09:16 PM   #5
cvicky
cvicky's Avatar
4 brl T pot holey
Old 11-14-2020, 06:29 PM   #6
Daves55Sedan
If you're not interested in 100% original integrity, just find a 1957 or later dry type that fits your carb.
Old 11-14-2020, 09:19 PM   #7
55blacktie
I don't believe a 57-up air cleaner assembly will fit the Holley 4000 "Teapot." Oil-bath air cleaners are efficient, but it sounds like you prefer the convenience of a disposable paper element, which Ford used, beginning in 1957. A paper element is fine. When it's dirty, replace it.
55blacktie is offline   Reply With Quote
Old 01-07-2021, 11:51 AM   #8
Cholo
I am restoring a 56 fairlane 2 door sedan, original oil bath reservoir has filter that can't be replaced....... can it be cleaned, has anyone done it or can I just keep using it like that since air particles fall to ground and rarely into carburetor. thanks for all input
Cholo is offline   Reply With Quote
Old 01-07-2021, 02:27 PM   #9
robib
You must be driving your car over ten thousand miles a year.
robib is offline   Reply With Quote
Old 01-07-2021, 08:52 PM   #10
dmsfrr
dmsfrr's Avatar
Originally Posted by Cholo View Post
I am restoring a 56 fairlane 2 door sedan, original oil bath reservoir has filter that can't be replaced....... can it be cleaned, has anyone done it...
Does it have a metallic mesh looking material inside the air cleaner lid?
If I remember correctly (it's been about 45 years) you can rinse them out with solvent then let it dry and re-oil.
Also drain out the old oil from the base, wash out the base with solvent, dry and refill it to the indicated level.
dmsfrr is offline   Reply With Quote
Old 01-07-2021, 08:54 PM   #11
55blacktie
The 1955-57 Thunderbird parts stores offer a reproduction chrome dress-up air cleaner assembly with a paper element that will fit 55-56 Teapot carburetors, but it isn't cheap.
Old 01-07-2021, 11:46 PM   #12
Kurt in NJ
Kurt in NJ's Avatar
When the oil is at the proper level some is sucked up into the mesh when it drains back it carries dirt with it so the mesh is pretty much self cleaning
Old 01-08-2021, 08:12 PM   #13
paul2748
paul2748's Avatar
dave55sedan is correct in saying that the oil filter is better than a paper filter. I little messy, but no big deal to service
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-29-2021, 04:06 AM   #14
cdgray899
I've heard that dust particles can still make it through, and that at times the oil droplets can get into the air intake. I've been on the fence about ditching my oil bath, what do you think?
cdgray899 is offline   Reply With Quote
Old 01-29-2021, 08:38 AM   #15
KULTULZ
KULTULZ's Avatar
Post Re: oil bath conversion
PERSONALLY ... ...
I have no use for one unless the vehicle is a dedicated restoration. A paper element is going to allow some particulate through as will an oil bath but not an oil mist like you describe.
NASCAR outlawed them in the late fifties. Also think of the K&N oil impregnated filter that they say will not allow oil migration but FORD says not to use, period. That filter can and will cause MAF failure and throttle body contamination.
If a nice car maybe find another filter assy to modify and save the best one for either restoration or the next buyer?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 01-29-2021, 09:44 AM   #16
Merc Cruzer
Merc Cruzer's Avatar
Prior post that you might find interesting:
https://www.fordbarn.com/forum/showt...ner+53%27+Merc
Merc Cruzer is offline   Reply With Quote
Old 02-18-2021, 08:16 AM   #17
49coupe
i have seen someone adapt a washable cone filter. Depends on the amount of fabrication you want to get into.
49coupe is offline   Reply With Quote
Old 06-14-2024, 12:04 PM   #18
Randy Knight
I bought a replacement top cover as the original has a couple of dents in it. Is there a way to use the new cover with a paper filter with the existing base? This is for a 55 T-bird.
Randy Knight is offline   Reply With Quote
Old 06-17-2024, 06:11 PM   #19
KULTULZ
KULTULZ's Avatar
REFER TO - https://www.fordbarn.com/forum/showt...97#post2318697
Old 07-12-2024, 03:48 PM   #20
KULTULZ
KULTULZ's Avatar
Arrow Re: oil bath conversion
Originally Posted by KULTULZ View Post
PERSONALLY ... ...
They are fire hazards on an automobile. That is why NASCAR outlawed them (and also why the manufacturers went to the dry type).
It is bad enough to run the roads with a H4000 with the fuel bowls above the carb venturies, but an oil bath ACL just adds another seat cover sucking situation if that oil ignites.
They are fine (IMO) for a dedicated restoration or a farm tractor if you don't pull wheel stands with it.
