Old 11-09-2020, 02:40 PM   #1
Charlie ny
Default '46 - '48 spark plug wires
I would appreciate a photo or verbal description of how the driver side spark
wires are routed. The conduit does not seem to have an eyelet adjacent
to #5 and #6 and #7 are on top of each other. The customer supplied the conduit and I'm not sure it is correct. Although the book calls for a 2 piece rabbit ear cap his choice is a crab cap.
Thank you,
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-09-2020, 08:31 PM   #2
Will D
Will D's Avatar
Default Re: '46 - '48 spark plug wires
Hopefully these pics help. The drivers side conduit should be a mirror duplicate of the passengers side. I just installed new wires and cap. 1 pic is the old cap and wires showing were they went to plugs. The other is routing the wires and completed drivers side. Oil filter makes it hard to see. Assuming it's the same conduit for rabbit ear style as for crab.
Will D is offline   Reply With Quote
Old 11-09-2020, 09:16 PM   #3
Charlie ny
Will,
Thank you so much...this the information I needed.
Charlie
Old 11-10-2020, 01:54 PM   #4
Will D
Will D's Avatar
Originally Posted by Charlie ny View Post
Will,
Charlie
Perfect
Old 11-10-2020, 04:06 PM   #5
flatjack9
flatjack9's Avatar
The conduits are different because #3 and#5 must cross to the opposite side of the engine with the crab cap.
Old 11-10-2020, 05:17 PM   #6
rotorwrench
rotorwrench's Avatar
The crab was only really used that one year in 1942 so I'm sure folks noticed that they were not a very well sealed set up. The war years brought in the rabbit ear type to help seal the moisture out better. The hot rodders seemed to like the crab though.
Old 11-10-2020, 07:23 PM   #7
Charlie ny
Guys,
Shaking things out my fix was to mill the required eyelet holss in the appropriate locations to route #5 and #6. Both conduits drop down between the water pump/s and distributor and position the SP wires right at the crab cap...quite nicely. I've never seen this style conduit before.
Again, many thanks.
Charlie ny
