Old 11-08-2020, 08:33 PM   #1
hotcoupe
hotcoupe's Avatar
Default It's a MIRACLE!
Well, not quite a miracle, but now that i have your attention . . ., i wanted to show you how i went about installing a hidden pcv system in my 81A motor. I used an original '37 intake manifold and i wanted each cylinder to share equally in the controlled vacuum leak. I'll let the images show the details. I put about one thousand miles on the truck with the new pcv system, today i changed oil and the motor has not leaked a drop of oil!
Tom
File Type: jpg IMG_08112020_185755_(800_x_600_pixel).jpg (145.1 KB, 407 views)
File Type: jpg IMG_08112020_185859_(800_x_600_pixel).jpg (171.1 KB, 385 views)
File Type: jpg IMG_08112020_190114_(800_x_600_pixel).jpg (125.8 KB, 360 views)
hotcoupe is offline   Reply With Quote
Old 11-08-2020, 10:18 PM   #2
Rudolph
Rudolph's Avatar
Default Re: It's a MIRACLE!
Nice, did the oil stay clean? I have just installed PCV on my 81 engine, I don’t get moisture on the breather on a cold morning anymore.
Rudolph is offline   Reply With Quote
Old 11-08-2020, 11:20 PM   #3
Ol' Ron
Ol' Ron's Avatar
Well done. Kinda thinking out of the box, I like it.
Gramps
Old 11-08-2020, 11:27 PM   #4
cajunfirehawk
cajunfirehawk's Avatar
By chance are you an engineer? Nice work, very detailed, imagine not cheap either?
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 11-09-2020, 01:41 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
We have many non-engineer types here on the 'Barn capable of doing a project like that, although Tom (hotcoupe) has seemingly done a very nice, professional-looking installation there. Another FordBarner (Heard) and myself recently did a PCV installation on his new 8BA engine. We engineered it such that the intake manifold does NOT require removal to service the PCV valve....clean and simple. Full article with parts list and pictures...click the link below! DD
https://www.fordbarn.com/forum/showt...=pcv+valve+8ba
Click Links Below __
T5 W/TORQUE TUBE
Old 11-09-2020, 08:03 AM   #6
KGS
KGS's Avatar
DD, Totally sano dude! Well done.
KGS is offline   Reply With Quote
Old 11-09-2020, 10:38 AM   #7
V8COOPMAN
V8COOPMAN's Avatar
Awe Shucks! DD
T5 W/TORQUE TUBE
Old 11-09-2020, 01:24 PM   #8
Rudolph
Rudolph's Avatar
I will make a copper line for this one day
File Type: jpg 476ECDE1-9AE3-42FA-8A64-3B3737E2C0CD.jpg (53.5 KB, 97 views)
Old 11-09-2020, 09:19 PM   #9
Newc
Newc's Avatar
What about the oil pan vent [48 back] ? I welded mine closed to prevent the road dirt from entering. Newc
Old 11-09-2020, 10:56 PM   #10
hotcoupe
hotcoupe's Avatar
Thanx for the positive comments, i know i mentioned it before, but after a thousand miles the outside of the motor is bone dry, no leaks anywhere!
Newc, good question regarding the pan vent, i used a stainless steel shim (0.015") to block off the vent. I forgot to mention it in my original posting.
Tom
Old 11-10-2020, 07:17 AM   #11
cadillac512
cadillac512's Avatar
That's good work. Nice job with the timing pointer as well...very professional.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 11-10-2020, 10:29 AM   #12
Zeke3
Zeke3's Avatar
Hotcoupe, great looking installation of the PCV. What are you using for a rear crank seal on your 81A engine, did you modify the crank to take a rope seal?
Zeke3 is offline   Reply With Quote
Old 11-10-2020, 11:44 AM   #13
hotcoupe
hotcoupe's Avatar
Zeke3, again another detail i omitted, i'm new at starting new threads. Yes, i had the crank ground so that i could use a rope seal on the rear main bearing.
Cadillac512, thanx for the positive comment regarding the timing pointer. I think that the simplest way is usually the best way.
Cajunfirehawk, the cost was minimal, probably less than $100.00, but the benefit of not having oil leaks and sludge build up in the motor. . . Priceless!
Tom
