11-02-2020, 01:33 PM | #1 |
Piston to Head Clearance Input
Hello All:
I have read through a few of these threads, need some input on what I have: 4 inch stroke, 3 5/16 bore w/ Ross Pistons, Brand New Navarro Heads and New Best Graphtite Gaskets. New ARP Studs. Aluminum Foil at sides and center of piston- torque to 40 lbs: Clearance Middle = .120 Edge of Piston = .075 It seems compression would be way down. How much should I take off the heads?? Thanks Guys, Dave |
11-02-2020, 03:00 PM | #2 |
Re: Piston to Head Clearance Input
That is a little bit funny, seems the chamber design of these new Navarro heads (from H&H???) doesn't have a consistent radius over the dome - or the radius is very different from the standard Ross .187" high radius. Hmmmmmm . . .
If the head chambers had a consistent dome radius (that is very similar to the Ross pistons), then your clearances should be the same across the whole top of the piston. (Or at least quite close) Lets find out a bit more about the chamber radius before you decide to do anything else. Note: I have NOS Navarro heads on my 284 stroker - but I custom matched the chambers to the piston Domes (via a CNC mill). I tend to pop the piston up a bit (custom compression height pistons) - then "tune" the chamber to match. If I have to mill the heads to get the final squish, then this is what I do. In the end, I would like to see a consistent .040 to .045 over the pistons - this gives you the best performance (squish is super important - maybe even more than compression ratio). If you can send me a couple hi-res pictures of the heads, would like to see the chambers. eMail: [email protected]. |
11-02-2020, 03:01 PM | #3 | |
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-02-2020, 03:13 PM | #4 |
Lots more issues with the "new" Navarro's than what's apparent, including cooling hole misalignment?
Do a search, I checked these out very closely for a recent blown build here? Thanks, Gary in N.Y. P.S. Had words with H&H back then will NOT use or sell them here no matter what! Here's a few shots, with your short stroke and assuming they are also 80cc heads be a bit tough on the final C.R.
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 11-02-2020 at 03:21 PM. Reason: Add photos |
11-02-2020, 03:40 PM | #5 |
Thanks Ronnie:
Stock size valves- 1007b camshaft. Looking to run two 48’s. Just looking for a zippy street motor. In terms of compression, I guess I should be asking- with a stock deck and a given gasket, what should my compression be with those pistons and heads?? (Shouldn’t HnH be able to tell me)? I would think the radius should be consistent over the dome as commented above. Do I have a bum set of heads?? Thanks Again |
11-02-2020, 04:01 PM | #6 |
You can also do it by measuring everything separately, but you'll find it is a bit more work (needing a plexiglass plate) - measuring the head, measuring the block valve/relief area, the head gasket area and then subtracting the dome area. Good luck! |
11-02-2020, 04:46 PM | #7 | |
11-02-2020, 05:22 PM | #8 |
You might gain some insight by reading the thread GOFAST started on the H&H heads.
11-02-2020, 05:39 PM | #9 | |
There's really no way for the radius of the dome to be identical to the top of the piston unless both parts were made by the same company that way they would actually match. Back when Barney Navarro was making the heads he no doubt had the dome matching similar to what ever piston was popular at the time. It may have been the shape of the stock Ford piston or at the time the popular Jahns pistons. Heck when i made my doming tool back in the last century we used the Jahns piston dome as our model that was way before Ross pistons. The fact the radius is not consistent will not effect how well your engine will run its certainly something interesting you discovered but really nothing to worry about. The one area I pay very close attention to on original older heads and todays new production heads is the water hole locations in relationship to the brand of head gaskets being used. That by far is extremely important. Ronnieroadster
11-02-2020, 05:50 PM | #10 |
FYI: As a side note, there are TWO different Jahn's piston domes - the one on the 3 ring "racing pistons" used a consistent radius, the one on the 4-ring stock-style pistons used a multi-ellipse pattern - essentially two different elliptical profiles on the same dome.
There are a variety of different piston crown/dome styles - some with a consistent radius, some with the multi-elliptical radius. I've seen different chamber/dome shapes on various Navarro heads over the years (original sets) - but I have no idea as to what H&H is doing these days. |
11-02-2020, 09:45 PM | #11 |
Dave,
I've mention my method of matching chambers and domes & determining valve clearance....... I'll use alum foil balls to begin the process to determine how much to mill the heads. Part of that is to attach the head without the gasket to the block and turn it over by hand a few times. If the average crush on the balls is .060 I'll have head milled that much. Now comes the multi hour massage.....using prussian blue on the piston domes and the heads of the valves, it's messy. The head is hung on the block with 4 studs and using arm pressure to hold the head down I spin the motor over a few times. Removing the head and flipping it over I can plainly see areas of contact and patiently blend those areas away using my trusty high speed air grinder. In most cases a head is off and on 20 times and the process per head is usually 10 to 12 hours. You must take your time. I'm on my 6th motor using this process and interestingly while it's not CNC it surely fits the head to the block perfectly. Something that comes to light is one bank will be off to the front the other side will favor to the rear. With this proceedure the head gasket is out of the equation until final assembly...this is where the .040 piston to head clearance is addressed....a crushed BEST head gasket is .040. I will tell you when I wind either motor up to 5000 plus I think about that .040 and rod stretch but so far so good. Charlie ny |
11-02-2020, 10:17 PM | #12 |
I agree with everything "Charlie ny" said above. I have been through the heads off and on 20 times as well. Although cast iron heads can be made to perform as well as fancy aftermarket finned units, I only use the aluminum heads because they're not nearly as much work as the iron ones. I guess I'm just lazy, though I do like the looks of the finned units.
Again, this is probably the cheapest and most important thing you can do to improve flathead performance. It sounds like you may have bit of a problem with the larger than normal variation in the clearance in various areas. This is where judgement comes in to decide between the amount of grinding you do versus the amount initially milled off the heads. Last edited by tubman; 11-03-2020 at 10:04 AM. |
11-02-2020, 11:36 PM | #13 |
I still can't believe their still putting the sparkplug in the same place they did back in the 30's. The original reason was to clean the spark plug. Modern designed combustion chambers place the spark plug where it will doo the most good for a complet combustion of the AF
Considering the fact we are so concerned about piston to head clearance, there is a reason why! The large area of the piston diameter contains the majority of the AF as the piston reached the top of the cylinder it pushes all this mass at the spark plug, and the ideal place would be in the center of the transfer area. With all the money and time people spend on improving the old flathead, you'd think they would consider something a trivial as this. But changing patterns are expensive. Just had to get this off my chest Gramps |
11-03-2020, 08:30 AM | #14 |
If you read my book you will find the Navarro-H&H clearances in your post are typical of the problems I pointed out. There is no easy path to perfection. However, that does not mean your engine will not run just fine. I suggest setting the minimum clearance at .050-.055 when using new Ford rods and a little tighter with used Ford rods but not less than .045.
And, I agree, the sparkplug should be moved. |
11-03-2020, 10:05 AM | #15 |
Well, they are moved, just a little, on Edmunds heads (at least the 8BA versions).
11-03-2020, 10:06 AM | #16 |
Ron & John,
For my education where do you guys consider the transfer area to be ? AND How proper would it be to bore 1" dia holes in each transfer area and press/ furnace braze steel 'bushings' (with SP threads) in those holes ? I'm getting ready for long winter. Charlie ny |
11-03-2020, 10:58 AM | #17 | |
11-03-2020, 11:02 AM | #18 |
The obvious advantage is spark plug selection, if nothing else.
11-03-2020, 11:16 AM | #19 |
I am able to run extended tip spark plugs in my engines and I believe it helps a lot.
11-03-2020, 12:00 PM | #20 |
Thanks for the information guys, I appreciate it.
