#1 |
I have a 1934 horn with a condenser and horn is not working; would like to replace the condenser. My question(s): 1.) what condenser do I replace it with? 2.) The original condenser is a 2 wire condenser- can I find a 2 wire condenser and 3.)which wire goes where when replacing.
Thanks Henry |
#2 |
Your Sparton horn condenser is .2mfd 400 volt. Look them up on ebay,very cheap. They have a wire out of each end. The condenser is connected across the horn contacts or in other words each condenser wire goes to each horn contact, soldered onto a tab. Easy to fit. The horn requires a condenser to work nicely. Regards, Kevin.
#3 |
THANKS for your input!! Will follow your directions. Henry |
