Old 10-21-2020, 05:32 PM   #1
DaveBPT
Default vacuum source
Newbie to early V8's. Where and what is the source for the wiper vacuum. I have a loose line with a brass fitting floating around the fuel pump.
Thanks
DaveBPT is offline   Reply With Quote
Old 10-21-2020, 05:38 PM   #2
petehoovie
petehoovie's Avatar
Default Re: vacuum source
What year flathead? Post a picture of what you have if you can....
Old 10-21-2020, 05:55 PM   #3
51woodie
51woodie's Avatar
You don't say what year, but the vacuum source on my '46 comes from a port located just below the carb on the back side of where the carb bolts on. The steel line goes to the distributor advance plunger and the rubber hose goes to the wipers.
51woodie is offline   Reply With Quote
Old 10-21-2020, 06:04 PM   #4
51woodie
51woodie's Avatar
Forgot to attach this picture of the vacuum source. The silver colored part with the hex goes through the banjo fitting with a copper washer on each side of the banjo.
Old 10-21-2020, 06:48 PM   #5
flatjack9
flatjack9's Avatar
The banjo line goes to the distributor.
Actually to the port in the front cover. The hose is for vacuum wipers.
Old 10-21-2020, 07:05 PM   #6
Will D
Will D's Avatar
What's the silver thingy right after the banjo but before the rubber hose called? Does it have internals? A one way valve Or just a fitting.
Will D is offline   Reply With Quote
Old 10-21-2020, 09:15 PM   #7
51woodie
51woodie's Avatar
As far as I know, it’s just a fitting. When I had it apart,I could see through it, so unless a previous owner did something to it,it’s just a fitting to make the connection.
Old 10-22-2020, 11:07 AM   #8
DaveBPT
Sorry I didn't put year. It is a stock 35 V 8
Old 10-22-2020, 12:48 PM   #9
ford38v8
ford38v8's Avatar
Dave, If your engine is stock as you say, the fitting will screw into the aft driver side intake manifold. It will be a threaded hole near the manifold's mounting bolts, similar to another vacuum hole on the same line forward, which should be connected to the distributor for the vacuum break. The previous answers given you would be correct for a later engine.
Alan
ford38v8 is online now   Reply With Quote
Old 10-22-2020, 12:54 PM   #10
JSeery
JSeery's Avatar
Not real easy to see in this photo of the top, but if you look at the bottom of the manifold you can see the channels that connect two adjacent ports for the vacuum source.
File Type: jpg 9D5D833B-E6DC-4A5E-8318-6B572CB6FD9E.jpg (79.4 KB, 54 views)
File Type: jpg 30AA76EB-2745-47D0-86ED-D6FBAC86542D.jpg (89.2 KB, 49 views)
Old 10-22-2020, 02:28 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
You are looking at the driver side of this intake manifold. There are TWO sets of DOUBLE holes. Find the set of 'double' holes toward the rear (right side of picture). The BOTTOM, threaded hole in that pair of holes is the vacuum source for your wipers. There is also a similar DOUBLE pair of holes toward the front (left in picture). The bottom, threaded hole in that pair is source for distributor vacuum. Same as JSeery picture above, but a little larger...easier to see! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-22-2020, 04:21 PM   #12
oldford2
oldford2's Avatar
I think that "silvery thing" is a silencer to quiet the manifold vacuum noise . ?? someone will know?
John
oldford2 is offline   Reply With Quote
Old 10-22-2020, 05:04 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
John
Seems like that's what I've read, also. DD
T5 W/TORQUE TUBE
Old 10-23-2020, 07:18 PM   #14
DaveBPT
Thanks Guys. Seems like someone put a bolt in the rear vacuum hole. I check in the morning.
Old 10-23-2020, 07:20 PM   #15
DaveBPT
Got the car started and running pretty well. Just bought it in July and had been sitting for 10 years. Sounds great!
