Old 10-10-2020, 06:54 AM   #1
Veeder
Default 41 ford choke & Throttle Rod rubber connections
What is the best way to attach the new rubber
Connections to the existing rods. The originals
Are crimped on. I've cut those off and am thinking
about using epoxy
Thoughts?
Veeder is offline   Reply With Quote
Old 10-10-2020, 07:48 AM   #2
fortyonerag
fortyonerag's Avatar
Default Re: 41 ford choke & Throttle Rod rubber connections
I have a buddy that used JB on them. Looks stock and works well.
I used a hydraulic cable crimper for some yacht wire balustrading I did a while back. Worked well but left hex crimp marks on the joints if thats a worry for you.
fortyonerag is offline   Reply With Quote
Old 10-10-2020, 08:53 AM   #3
Veeder
Thks unfortunately I don't have one. Of those the side that connects 1to the carburator arm I did in a vise 1 and it should be fine it's the side on the cable side I'm debating best approach
Old 10-11-2020, 04:23 AM   #4
fortyonerag
The JB my buddy did on his car looks great
