#1 |
My 46 has a dealer installed signal light (Allstate). Separate rear and front lights. I have a Brakelighter installed 5 years ago and has always worked great. Lately the brake light is bright when brakes are applied. Now the sides for left and right only flash lightly on a couple of the leds on either side. So I am trouble shooting. I removed the bulb from one of them and am only getting 2.5 volts on the meter.
First thoughts? Grounds/flasher? Thanks John |
#2 |
Good clean grounds first. For some reason I have found that the 41-48 cars definitely need really good clean grounds. I have even added a ground strap to the housing stud that protrudes into the back side of the fender. If you have a stock wiring harness also check all the bullet connectors at the back . Take them apart and clean them with sand paper and a round file in the tube encased in the rubber.
#3 |
