Old 10-05-2020, 11:46 AM   #1
black skirts
Question 1935 coupe-transmission removal
Need Guidance - We have a 1935 3 window that came with a later tranny with
matching original Ford column shift. Always worked great . Until now. The
question is....If I slide the rear back , will there be room to get the tranny out the bottom past the original crossmember or does it have to come out thru the
interior??? Thanks in Advance!!
black skirts is offline   Reply With Quote
Old 10-05-2020, 01:50 PM   #2
deuce lover
deuce lover's Avatar
Default Re: 1935 coupe-transmission removal
Out thru the interior.
deuce lover is offline   Reply With Quote
Old 10-05-2020, 02:05 PM   #3
drolston
drolston's Avatar
Starting with the '49 shoebox you could drop the transmission from beneath. Before that, they all come out from the inside of the vehicle.
Old 10-05-2020, 05:07 PM   #4
Pandersen33
Pandersen33's Avatar
Ive taken it out the inside several times now. Actually pretty quick if everything goes the way it should. Maybe 2 hours or so. If you pulled the tranny mount off and obviously the shift tower im sure you could pull it out the bottom.
Pandersen33 is offline   Reply With Quote
